2.7 EB Problems?
Old Aug 23, 2019 | 03:23 PM
  #61
JKBrad's Avatar
JKBrad
Or blowing the cobwebs out. These modern engines have high compression and are designed to be revved. If you baby them you will eventually have some problems. In my opinion, a wide open throttle run the gears once or twice a week is good practice.
I remember reading on this site years ago, some guys would brag about never taking their engine over 2000 RPMs. They felt that their engine would last forever that way. Maybe, if it was an old flathead. Old habits die hard. Especially if that the way your ol’ dad taught you.
Old Aug 25, 2019 | 08:46 PM
  #62
David W Jones's Avatar
David W Jones
I’m not sure about other 2.7’s, but mine redlines at less than 6k. My memory is poor but I believe that’s less than my 2012 Coyote. In no way does the 2.7 require high rpm to get its work done.
Old Aug 25, 2019 | 11:30 PM
  #63
JKBrad's Avatar
JKBrad
I never said the 2.7 needed max RPM to get the work done. All I said was to run it (or any engine really) through the gears at WOT once a week or so. I’ve done that with all of mine over the decades. Of the vehicles I’ve bought new, I’ve never had one use oil or sludge.
This is only a recommendation, your results may vary.
Old Aug 26, 2019 | 11:02 AM
  #64
Beechkid's Avatar
Beechkid
Originally Posted by tseekins
It's no secret that in town miles will kill an ecoboost just as quickly as a turbo diesel. That's why I'm looking outside the Ford stable for my wife's replacement vehicle because the majority of her miles are in town and I don't want to deal with the consequences AND Ford has bet the farm on the ecoboost.
Having said all that, my 2011 truck is amazing. I enter the freeway every day and hammer it, I change the oil every 5000 miles with MC 5w-30 semi-syn and nary an issue.
I believe that some of issues that surround the EB program is just the luck of the draw BUT, I do believe that most issues are the fault of the user for not doing more frequent maintenance and Ford for not telling people that they need to do more frequent maintenance.
Look, we all know that someone who had a seemingly bulletproof engine go bad long before it should have but that doesn't make all engines in the segment bad. I had a 1988 Ford 5.8L go bad at 89,000 miles but we all know this to be a great engine minus the wicked poor MPG's. All maintenance was spot on, just the luck of the draw.
I completely agree!!!!!! The engine (like all others) has to be operated in it's designed power-band.....if not, there are just going to be issues.....either a lot of ongoing maintenance, repairs or engine life...…. consumers in general IMHO are too quick just to "inhale" the PR material....when if they are lucky, they have picked the right drivetrain...….but many are not and then (expensively) disappointed.
Old Aug 27, 2019 | 05:42 AM
  #65
tseekins's Avatar
tseekins
Veteran: Coast Guard
Originally Posted by Beechkid
I completely agree!!!!!! The engine (like all others) has to be operated in it's designed power-band.....if not, there are just going to be issues.....either a lot of ongoing maintenance, repairs or engine life...…. consumers in general IMHO are too quick just to "inhale" the <acronym title="Page Ranking">PR</acronym> material....when if they are lucky, they have picked the right drivetrain...….but many are not and then (expensively) disappointed.
All of what you stated makes the NA V-6 the perfect in town engine for running errands and such.
Old Oct 2, 2019 | 09:15 PM
  #66
EdgarD's Avatar
EdgarD
2015 F150XL 2.7L Econboost
I just had they truck into service because Start/Stop feature stopped working. It was still under warranty and covered. The problem was a bad Transmission Auxilary Pump. 40,000 miles.
Old Oct 2, 2019 | 11:21 PM
  #67
JKBrad's Avatar
JKBrad
Welcome to FTE Edgar! We hope to see more of you in the future.
To be fair, the transmission had the problem not the 2.7 EB.
Old Oct 3, 2019 | 12:30 PM
  #68
Beechkid's Avatar
Beechkid
Very right!!!!!!!!!!!!!...….
Old Aug 19, 2020 | 02:34 PM
  #69
Beechkid's Avatar
Beechkid
Originally Posted by David W Jones
Why was a 2 year old turbo with 30K miles on it not under the power train warranty?
Ever since the Ford tech you linked to posted a picture of BMW valves to explain how Ford Ecoboosts would coke up, he lost all credibility.
I should have said...coking or soot buildup in the turbo wastegate assembly is not considered a "warranty item" per Ford it is a "maintenance Item" that must be done by the owner.
Old Aug 19, 2020 | 02:51 PM
  #70
NASSTY's Avatar
NASSTY
There's a 2.7 on another forum that I frequent that has almost 400,000 miles. Aside from normal maintenance , the only part replaced was a purge solenoid valve
Old Aug 19, 2020 | 03:30 PM
  #71
raytasch's Avatar
raytasch
Believe Nothing
Does that mean I must get into long periods of WOT more often?
Old Aug 22, 2020 | 03:11 PM
  #72
Shuf's Avatar
Shuf
4wd High
I guess I'm not up to speed on all the jargon around here. If you don't mind me asking, what does WOT mean?
Old Aug 22, 2020 | 03:13 PM
  #73
Tom's Avatar
Tom
Wide-Open Throttle. Flooring it.
Old Aug 23, 2020 | 05:08 PM
  #74
David W Jones
There is NO coking issue in the 2.7. Period. If there is with the 3.5, I’ve never seen a thread about it.
So, no. Regular Italian tune ups are not needed in an F150 EcoBoost.
Old Aug 24, 2020 | 12:25 AM
  #75
Papa Tiger's Avatar
Papa Tiger
I run a good de-carbon thru the fuel system at least 4 times a year, approaching 100,ooo miles now and have the spark plugs to put in it, but not one miss. Will do it in September when I replace the front rotors and Brake pads. Front tires lasted 95,000 miles, those dang rears were done at 85,000 miles. Happy camper, most likely aluminum Turbos keep the rears turning hard a lot. Lol
arizonasuperduty007
Arizona Chapter
May 8, 2012 04:55 PM
cwix
Mar 2, 2007 06:25 PM
wrenchturner
Jan 25, 2006 05:15 PM
MB4JH
Feb 3, 2003 09:51 PM
