Starter challenge
Old Nov 5, 2016 | 06:30 PM
Yahiko's Avatar
Yahiko
Starter challenge
Ok so I had a starter issue this last week. When I got to checking the 6.0L starter
I had replaced with the 6.4 starter I found that it also had the switched side nut on
both starters was loose.
This is what I would like every one to do. With the batteries disconnected. (We don't want a light show)
Check both of the nuts on the starter solenoid to see if they are loose at all.
Sean
6.0L Tech Folder
P.S. Get the cat snacks out before you call the cats for the snacks or you risk getting mobbed.
Really that goes for any pet and the snacks.
Old Nov 5, 2016 | 07:06 PM
TooManyToys.'s Avatar
TooManyToys.
Coming out: both of my nuts were tight.
Going back in: the assembled nut was tight when checked. The second nut was tightened by me.
I just checked my nuts again and both are still tight after a few days of getting heated up.
How often would you like us to check these?
Old Nov 5, 2016 | 07:20 PM
diesel_dan's Avatar
diesel_dan
^^^^ Am I the only only one that laughed out loud reading Jack's post??!
Maybe I've lived in CA too long....
Old Nov 5, 2016 | 07:23 PM
Yahiko's Avatar
Yahiko
No and my answer will really get you.
Sean
6.0L Tech Folder
Old Nov 5, 2016 | 07:24 PM
Yahiko's Avatar
Yahiko
Maybe anytime when you down there .
Sean
6.0L Tech Folder
Old Nov 5, 2016 | 07:25 PM
WatsonR's Avatar
WatsonR
No... Having been away from home the last week or so, I laughed as well
Old Nov 5, 2016 | 07:27 PM
Yahiko's Avatar
Yahiko
I really think that if you have worked on the starter then a recheck a few days
later after a few start cycles would do it.
The ones that should recheck are the ones that check and find something loose
the first time.
With a new solenoid mine starts so much better now.
Sean
6.0L Tech Folder
Old Nov 5, 2016 | 07:48 PM
TooManyToys.
Originally Posted by Yahiko
Maybe anytime when your down there.
At my age that doesn't happen that often. At 8-10k miles per year it only happens once maybe twice a year. But the next time should be in about a week, God willing.
Yahiko
Nov 3, 2016 11:57 PM
drs3
1997 - 2003 F150
May 22, 2009 05:55 AM
donjamer
New Hampshire Chapter
May 30, 2008 04:48 PM
NetCommuter
1997 - 2003 F150
Jan 21, 2008 04:59 PM
poffutt
1997 - 2003 F150
Nov 16, 2006 09:30 AM
