4R100 Interchangability
Old Nov 3, 2016 | 09:25 AM
GusEmery's Avatar
GusEmery
Let's just say my transmission our of my '00 Excursion 4x4 v10 just cracked.. (see attached pic).
Anyway I'm in need of a cheap transmission. My question is I'm seeing that the 5.4L and v10 6.8L 4r100 are not interchangable. Is this true?
The reason I question this, is that the Ford Parts site shows the same part number for both. :-|
Please help! I have a line on a good transmission close, and I would love to have an answer soon.
Thanks everone!
-G
Old Nov 7, 2016 | 09:53 PM
jk080's Avatar
jk080
Transmission Rebuilder
Can't answer your question on interchangeability but I wanted to mention that the cause for broken cases like this is not due from something inside the transmission failing but due to something loose on the outside like the extension housing or the transfer case or problems with the drive shafts.
Check everything that is attached to the transmission you would hate to have this happen to the replacement one.
Is that JB weld all over the extension housing from a previous repair attempt?
Old Nov 8, 2016 | 06:17 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Ford may be listing a 6.8L trans for a 5.4L. That will work. Putting a 5.4L trans behind a 6.8L isn't going to last long because the 5.4L version has less clutch plates.
Old Sep 12, 2019 | 11:13 AM
jaces99's Avatar
jaces99
wondering
i have a 2000 ford excursion 4x4 limited edition , wondering what trans would fit this it is 5.4 gas , i have a chance to get a gas 5.4 trans from a f250 super duty 2001 , would this work? i have people telling me only a excursion trans can be used in a excursion , but i have been told it is a f250 pretty much
Old Sep 12, 2019 | 08:36 PM
Mark Kovalsky
There are exactly zero differences between an Excursion and F-250/F-350/F-450-F550 transmissions.
You do need to match 4x4, though. A two wheel drive transmission will not fit.
rmgdunlap
May 10, 2018 04:14 PM
Matt Souza
Jan 11, 2017 06:23 PM
Ford'05HG
Modular V10 (6.8l)
May 9, 2014 04:17 PM
Rollerized
Sep 26, 2013 08:36 PM
