Dealer added in my instrument gauge cluster how close Im getting to regen
I'm at 47k miles and have gone through regen cycles and jugs of DEF with being a daily driver of a 70 mile round trip commute in rush hour traffic with some highway sprinkled in and a few thousand towing miles and have not had any regen related issues of any sort.
But I do know that clogged filters are an issue for city service vehicles that never see full cycles completed
There are times when I have just completed a regen cycle and pulled in the drive after a couple miles off the highway. Doesn't happen with that sort of timing as often as I would like but anyway.... Even then I can feel the heat coming out from under the truck (No its not just off the exhaust on a normal days drive) and I have heard about the temps the regen cycle generates.
If you do a manual regen while stationary and that heat just rises and bakes the underbelly I would be concerned with doing this on a regular basis. I admittedly don't know if there is a heat shield between the chamber and the cab underside but even still I would just do this only if you never or rarely go through the cycle normally.
I know there is this phobia about non completed regen cycles but aside from the always city driving issues I have not heard of any related mechanical failures from just completing the regen cycle as the sensors are programmed to.
73FOMO
12-09-2010 08:27 AM
gmbtowing
2004 - 2008 F150
05-14-2010 08:58 PM
