460 Oil Pan Removal
460 Oil Pan Removal
In a '95 F250 4x4 7.5L, is it possible to remove the oil pan without removing the engine? It looks a little tight in the front, but the rest looks manageable. I didn't know if I could maybe drop it down enough to remove the pickup tube or pump, and slide the pan out. Anyone do this before? Thanks
Thanks, I was just curious if anyone had attempted it. I'll already have the trans removed...figured it may be a good time to do it. Shouldn't be hard to lift the engine unless it has to come up so far that it interferes with something else. The bottom end is getting a little noisy...it's not bad but I figure it'll only get worse. I thought if I could get the pan off I could pull a rod cap or two and check things out.
And then you have to put the tube and two bolts and a nut *back* in the pan and re attach everything oil tight without disturbing the pan gasket.
There is an EPIC thread by Quakerj in the Bullnose forum where he swears he is going to burn the truck to the ground before he ever tries to replace a 460 pan gasket *in the truck* again.
But we are all waiting to be entertained.
Pull it if you can. I didn't have a cherry picker or stand to use so I didn't have much of a choice. I did a rear main seal. It can out fine
Pull it if you can. I didn't have a cherry picker or stand to use so I didn't have much of a choice. I did a rear main seal. It came out fine bUT it would've been way easier if I could've pulled the motor. The biggest pain in the *** was getting the oil pump rod seated back in the bottom of the distributor. I had to use an endo cam to make sure it was in right before I put the oil pan back on and dropped the motor back down. Otherwise you just have to hope that it's in there. You would know until you fire it back up and see in you have oil pressure, because you can't see the hole it goes in, you have to do it bu feel like your some kind of ****ing jedi or ray charles.
I've got too many other projects to tackle it right now. I'm reasonably convinced that it's piston slap, anyway. Only seems to do it at cold idle, much like a 5.4. I'm not really worried about it. It's got 376K miles on it. I was hoping for half a million, but if it craters today I can't complain.
I've done it a few times but its not easy. Unbolt the fan shroud and motor mounts and jack the engine up as high as possible, remove the pan bolts and lower the pan, then reach through the side and unbolt the oil pump and sump tube. Its far easier with the engine out of the truck but it is possible to do it in the vehicle.
AerostarDad
05-23-2017 09:37 AM
