Torque values for upper shock mount bracket
Old Nov 1, 2016 | 02:53 PM
Wheelman55's Avatar
Wheelman55
Driving down the road minding my own business and I heard a pretty good racket coming from the front passenger side wheel well. Busted shock mounting bracket. Too many bad roads down here in Terlingua.
Would somebody please give me the torque settings for the shock bracket that attaches to the frame and also for the shock bolts?
I found a set of OE brackets on eBay.
Thanks a million guys.
Old Nov 1, 2016 | 04:35 PM
F-ReV's Avatar
F-ReV
Just make the shock bracket bolts to the frame as tight as you feel comfortable going. As long as you don't break the bolts your good, torque specs aren't really necessary for that bracket. As for the shock just don't make it so tight that it crushes the bushing in the shock.
Old Nov 1, 2016 | 05:37 PM
Diesel_Brad's Avatar
Diesel_Brad
What he said^^^^ You are over thinking things but if you REALLY want to torque things
Bolt Torque Chart
Old Nov 1, 2016 | 06:01 PM
Onions.n.Butter's Avatar
Onions.n.Butter
This should be all you need. I punched in 1993 and this came up, so must be the same as 1992
Old Nov 2, 2016 | 03:21 AM
Wheelman55's Avatar
Wheelman55
Onions.n.Butter. Thanks! Where can I find those values that you punched up?
Old Nov 2, 2016 | 05:51 PM
Onions.n.Butter
I'm a tech at an automotive shop, I used Alldata Pro
Old Nov 4, 2016 | 03:14 PM
Wheelman55's Avatar
Wheelman55
Thanks guys. The mounts came today and I installed this afternoon.
Old Nov 4, 2016 | 05:48 PM
Wheelman55's Avatar
Wheelman55
Before and after pictures.
New upper shock mount.
Torn old shock mount. Got some rough roads here in Terlingua.
srsbjohnson
Aug 8, 2013 10:53 PM
rtcalabrojr
18
May 20, 2010 07:20 PM
trooth2u
Bronco II
Oct 19, 2003 07:34 PM
jschira
Feb 8, 2003 11:27 AM
sandrat
Nov 25, 2002 05:59 PM
