Sponsored by: Auxito
Front ABS issue?
Old Oct 31, 2016 | 08:36 AM
keyul's Avatar
keyul
Front ABS issue?
2003 F150 5.4L 4x4
I recently replaced my entire front end, new calipers, pads, rotors, steering knuckles, shocks, upper & lower control arms, inner & outer tie rods.
During the last few MPH before coming to a complete stop, the front left pulses, feels like the abs is activating on that wheel. It only does it probably from 3 mph down to a stand still.
The abs sensor was a bit stubborn taking out during the front end rebuild, I'm wondering if it got damaged, or if there could be something else going on?
Old Oct 31, 2016 | 10:45 AM
Bluegrass 7's Avatar
Bluegrass 7
Over torquing the front discs can distort them and cause this problem.
Or one disc is out of spec.
Good luck.
Old Oct 31, 2016 | 05:08 PM
keyul's Avatar
keyul
Good luck.
I think you're referring to brake shudder. Abs sensors read from a ring that is not attached to the disc.
I found my problem, the little wire is severed, time for a new sensor:
Old Oct 31, 2016 | 05:53 PM
steve(ill)'s Avatar
steve(ill)
you should have had an ABS light on if the wire was broken... would not pass startup continuity test.
Old Oct 31, 2016 | 06:56 PM
keyul's Avatar
keyul
True but there are two ends to that broken wire, and if they're both touching the metal inside the knuckle, it'll still make a complete circuit. Safe bet I need a new one though!
Bluef2.5.0
May 28, 2019 05:17 PM
edsheridan
Aug 25, 2014 02:39 PM
atesvn
Aug 11, 2008 11:01 AM
7700Rob
1997 - 2003 F150
Nov 13, 2007 06:52 AM
