what is this?
Old Oct 30, 2016 | 04:06 PM
Huskerman's Avatar
Huskerman
what is this?
This is the first Ford truck I have ever owned. What is this and what does it do? It has vacuum lines and a harness.
1999 2.5l engine.
Old Oct 30, 2016 | 05:03 PM
john jamieson's Avatar
john jamieson
Need a picture
Old Oct 30, 2016 | 06:47 PM
ranger pat's Avatar
ranger pat
Veteran: Navy
Probably an EGR purge valve. Can't tell without a photo. The computer tells the purge valve when to empty the carbon canister fumes back into the intake manifold.
Old Oct 30, 2016 | 07:39 PM
Huskerman's Avatar
Huskerman
Old Oct 30, 2016 | 09:18 PM
projectSHO89's Avatar
projectSHO89
That is the EVR solenoid. The PCM sends it a PWM signal that causes it to pass a regulated vacuum (based on the PWM duty cycle) to open the EGR valve by a calibrated amount.
There's no such thing as an "EGR purge valve"
Old Oct 30, 2016 | 09:38 PM
Huskerman's Avatar
Huskerman
So the vacuum hose should be connected to the EGR valve?
Old Oct 31, 2016 | 06:04 AM
projectSHO89
One of the lines off the EVR solenoid goes to the EGR valve (probably green), the other goes to the manifold supply via whatever routing was intended. There should be a label somewhere under the hood with the vacuum schematic on it..
TedHJ
Jul 31, 2015 11:16 PM
stevenjf88
Jun 5, 2015 05:05 PM
PAULAU123
Sep 16, 2011 08:20 PM
77trailerspecial
Oct 29, 2010 09:24 PM
