pre-bent brakelines
Old Oct 26, 2016 | 11:41 AM
KennyCoulter's Avatar
KennyCoulter
pre-bent brakelines
I have tried searching....
The only lines that I am finding online are for 2wd. Are any pre-bent lines available for the 4wd trucks? I have been told by a vendor that they ARE indeed different, and that they do not have 4wd versions available.
Old Oct 26, 2016 | 08:30 PM
john jamieson's Avatar
john jamieson
Before going the route of prefabed lines, Take a good look at where yours are and think: Will I be able to get a prefabed line in place? It may be easier to buy a roll of tubing and fittings and a flaring tool and make your own. There are kits on ebay that have everything together and you have enough tubing to do a lot of practice.
Old Oct 27, 2016 | 12:13 PM
KennyCoulter
Thank you for the reply.
I never thought about the possible difficulty in getting the pre bent lines in place.
A friend bought a ranger that had some lines replaced, with the old lines removed and the new ones not placed in the original locations. I will not be doing the work on the vehicle and he is looking for the easiest way to get things done (correctly). He did talk about being able to flare his own, but I advised against it, as he doesn't have a lot of experience....and I myself have not had good luck with flaring my own lines.
Old Oct 28, 2016 | 07:45 PM
98 Thunderbolt's Avatar
98 Thunderbolt
Post Ummm......
I wouldn't think that the hard lines that run the frame rails would be different 2wd - 4wd, same length and size, only difference would be the length of the hosed lines to the calipers & rear axle.
I know that Ford lines are not available for long before they to have to purchase the sticks & bend them.
Old Oct 31, 2016 | 07:55 AM
KennyCoulter
I was thinking the same, but I couldn't actually confirm anything. The guy who is fixing it is on a budget, so it might hurt him to purchase what are labeled as 2wd and they happen to be different...and can't return them.
Old Oct 31, 2016 | 12:47 PM
KennyCoulter
From the seller/vendor:
Yes the 2wd lines are routed differently than a 4wd truck. At this time we do not have the lines available for the 4wd. trucks. Thanks
Old Oct 31, 2016 | 06:34 PM
02FX4Dude's Avatar
02FX4Dude
Back in 2007 when I was rebuilding my old F150 I bought a pre-bent stainless brake line kit from Bronco Graveyard and it was awesome. 30 minutes to rip out all old brake lines including some splices I had put in, about 45 minutes to install new lines, then bleed with speed bleeders.
I wish I could find a similar set for my Ranger.
SoCalAngler
Jan 16, 2018 01:42 AM
vettman
Aug 21, 2006 03:53 PM
deisele75
Feb 18, 2005 11:50 PM
chas4x4
Feb 9, 2004 07:06 AM
