Sponsored by: Real Truck
LED Headlights
Old Oct 26, 2016 | 08:27 AM
jonrjen's Avatar
jonrjen
LED Headlights
After spending some time driving the back roads with the use of my LED aftermarket lights and light bar that are attached to my grille guard I have become much more aware of the poor lighting of the OEM headlights ability to provide safe lighting.
I have watched this manufacture for the release of their product which is a direct plug n play installation but haven't come across any reviews.
Is anyone running these?
https://www.lifetimeledlights.com/le..._led_headlight
If so what is your personal opinion?
I have read some post that say to stick with your OEM supplied bulbs doe to the reflective optics of the housing being designed for such bulbs and the installation of LED bulbs are not truly compatible and as such do not throw a beam but rather display scattered light.
Old Oct 26, 2016 | 09:44 AM
Mike189677's Avatar
Mike189677
Here's what I posted about mine not long ago. As for the scattered light my beam pattern was very similar to halogen on low beam correct placement of the light in the housing is very important. Mine were the older version of their lights though. They are really bright right in front of the truck and it makes it hard to see down road which isn't bad on low.
Originally Posted by Mike189677
I recently just took my LED headlights out they just aren't where they need to be yet with the recflector headlights housings and I don't know how they work in projectors but I'd rather use hids in projectors anyway I know they work. And none of them are actually legal to use on the road even the ones like my lifetime led bulbs that said they were dot approved on their website but there is no dot number. Everyone that makes them has concentrated on making them so bright and not enough on the beam pattern. They are so bright infront of the truck and the down road and pretty much washed out for lack of a better term down road which isn't very good and the high beams are completely useless. And mine were positioned in the housings correctly which is very important and aimed properly as well. There is another member on here with an 08 but his is an xl model and I think it's ge that makes a replacement for the sealed beam housing that is awesome. The best thing you can do is either have projectors retrofitted into stock headlight housings and use hids which need to be in a projector housing or just get some sliver star ultras or equivalent from ge or Phillips and just live with it till someone comes up with a better led solution.
Old Oct 26, 2016 | 01:23 PM
Tractionless's Avatar
Tractionless
As far as light scatter goes I've had HID's in halogen housings followed by LED's and the LED's offer the same light pattern as the halogen bulbs, just much brighter. Be sure to get a high wattage and high LM rating. Also the LED's listed above are way more $$ than they need to be, not to mention the fans are old tech. There are now cooling straps which makes fitment much easier.
Old Oct 26, 2016 | 04:55 PM
FordBlueHeart's Avatar
FordBlueHeart
I've heard great things about the LifetimeLEDs. You might want to check out this thread too. There's a group buy going on for the fog lights.
https://www.ford-trucks.com/forums/1...eadlights.html
Sir Aaron
Jan 19, 2018 01:06 AM
adbscu
Dec 11, 2015 12:35 PM
Bushman512003
Oct 6, 2010 08:24 PM
GR$$N$
Feb 2, 2009 04:23 PM
Joeymt3
1983 - 2012 Ranger & B-Series
Sep 12, 2008 09:12 PM
