I need some motor swap help
The flathead is now out of my 48 F2, and the 302 from the 68 Mustang, is ready to install into the truck.
I see there are 2 different types of mounts available from Mid Fifties.
One type is
1948-72 Ford F-100 Motor Side Mounts, Ford Small Block - 4145
The other is a complete cross member
1948-64 Ford F-100 Crossmember Engine Mount, Ford Small Block 221-289-302-351 Windsor - 4819
Anybody have any experience with these kits?
Is one type easier than the other?
One type is
One type is
One type is
I used the second one also. I installed the motor and AOD tranny together and marked the locations of both the cross members. I drilled a 5/16 hole thru the ends and installed a bolt to hold it there.Then I removed E&T and welded cross member, then bolted it into the frame rails. Went pretty easy.
I positioned my 351w with the c-6 transmission attached to clear the Toyota steering box. I fabricated my own engine mounts and moved the original trans cross member rearward. The frame is a different width at this new location so I fabricated a pair of shims on each side of the cross member. The engine and trans is centered in the frame.
HkyswiM
05-07-2013 12:07 PM
73FOMO
12-13-2006 08:41 AM
