Ford 302 motor mount help
Old May 7, 2013 | 11:52 AM
HkyswiM's Avatar
HkyswiM
Hey guys
I found a great deal for a 302, aod tranny, wiring harness and computer for the engine since its a fuel injected from a 85 pickup truck.
Before I buy this I was checking the mid fiftie site and saw they offer a crossmember for a 302. Do all 302's use the same mounting locations? If not does anybody have a link to a crossmember that will work, I can't seem to find one that specifies years for 302.
Thanks
Mike
Old May 7, 2013 | 11:58 AM
dmack91's Avatar
dmack91
I believe they are all the same. I built my own frame mounts and used factory style block mounts, but have heard of many people happy with the crossmember style,either bolt in or weld in.
The only thing to watch is that if you have or may go to an IFS, the tubular crossmember style may not clear the IFS crossmember.
Old May 7, 2013 | 12:07 PM
CharlieLed's Avatar
CharlieLed
The dimensions of the mounting holes on the block are the same...however, there are different style motor mounts. Many like the early Mustang style with the single downward facing bolt...I personally like the one with the u-shaped bracket, it makes it easier to fabricate the mating mount on the frame. Most of the tubular SBF crossmember designs use the u-shaped mounts.
GreatNorthWoods
16
Sep 17, 2009 02:51 PM
dick1950
Oct 2, 2006 02:10 PM
77effie
20
Mar 17, 2006 12:31 PM
nomadshirt
Feb 12, 2006 05:21 AM
tip49
Dec 22, 2004 07:18 PM
