Shock Question.
Old Oct 23, 2016 | 06:06 PM
KsHighboy's Avatar
KsHighboy
Shock Question.
Should a shock extend itself if you compress it and let go? Or, does it have equal resistance extending an collapsing? If I collapse or extend mine they just stay where you left them. These are on my dual steering stabilizer so I don't know if they act different than a regular shock.
Old Oct 23, 2016 | 06:35 PM
Ford_Six's Avatar
Ford_Six
That is correct for a steering stabilizer. If it extended itself, you would be constantly fighting it. Gas charged shocks extend due to the gas pressure inside, which helps prevent the oil from foaming. Steering stabilizers don't cycle as much so it's not a concern.
Old Oct 23, 2016 | 07:11 PM
HIO Silver's Avatar
HIO Silver
Steering stabilizers are intended to absorb or at least slow down the feedback through the steering linkages to the driver. For example, if yer wheeling and suddenly impact a rock which causes a wheel to suddenly turn.... the stabilizer slows the rate at which the energy (movement) is transferred so ya don't break yer thumbs by the steering wheel suddenly turning.
Old Oct 24, 2016 | 12:09 PM
351Cleveland C4's Avatar
351Cleveland C4
Right. Just as the others have said it.
Old Oct 24, 2016 | 03:24 PM
KsHighboy's Avatar
KsHighboy
Thanks guys. I just checked my front shocks also and they do not extend themselves if you compress them. They just stay compressed. They are Rugged Trails that I bought 20 years ago but I don't know if their nitrogen filled. They have pretty good resistance when you push them in or pull them out though. Do only the nitrogen filled extend themselves?
Old Oct 24, 2016 | 03:27 PM
Brian1971f100's Avatar
Brian1971f100
yes only gas charged shocks will extend themselves.
Old Oct 24, 2016 | 06:13 PM
CougarJohn's Avatar
CougarJohn
Yeah, how well I know with my experience on my '34. No dropped wishbone, solid axle, kingpins, the thing would go into a terminal shudder after a pothole strike about every six months. And bumpsteer. Hit a bump and it would move a half lane to that side. A stabilizer out of a Toyota solved all the problems.
I was not aware that stabilizers are still and issue with independent I beams but it is good to know.
Gracias, Hio.
'12 Duty Super
6.7L Power Stroke Diesel
Aug 22, 2015 09:31 AM
nghtrgr
Jun 2, 2010 12:34 AM
cencarcat
Oct 18, 2008 10:11 PM
CptSD
Offroad & 4x4
May 4, 2007 09:04 AM
mlc5967
Jan 28, 2003 12:43 AM
