ABS light on
Old Oct 22, 2016 | 09:10 AM
Jaaaaaaackman's Avatar
Jaaaaaaackman
ABS light on
My brakes work perfect and I have an ABS light, I disconnected the battery hooked it back up the next day and still have a ABS light, how does one turn off the ABS light?
Old Oct 22, 2016 | 07:57 PM
MoBill122's Avatar
MoBill122
Papa Smurf
You need a Code Reader that will read the ABS codes. Not all Code Readers read ABS.
Might be the sensor on rear end, as its known to go bad.
I rode around with a ABS light on for over a year... never did feel like anything was wrong.
Old Oct 22, 2016 | 11:00 PM
mcali2's Avatar
mcali2
I gave up on mine replaced everything but computer . must be a short .
Old Oct 23, 2016 | 05:08 AM
MoBill122's Avatar
MoBill122
Papa Smurf
Replaced the ABS cable to hub... but that didn't work. Later on I finally replaced that hub and that was end of problem.
Old Oct 23, 2016 | 06:14 AM
tjc transport's Avatar
tjc transport
i ain't rite
i just remove the bulb from the dash, the only vehicle i own that has working ABS for now is the 02 diesel.
and that is going to get the abs disabled very soon because the brakes suck on that truck.
Old Oct 23, 2016 | 07:59 AM
krifenbu's Avatar
krifenbu
I am not at my computer this weekend, so I won't go into great detail on this. The OBS trucks don't run ABS codes through the PCM so you can NOT pull them with a code reader.
First question will be does the red e-brake light work?
If you will search the forum for my user name with ABS you should find a thread showing the process for finding the wire to ground that will have the dash light blink out the error code.
Kevin
Old Oct 23, 2016 | 10:19 PM
Jaaaaaaackman
giggled the connector and the light went out , happy happy........
Old Oct 24, 2016 | 06:46 AM
Jarrett Campbell's Avatar
Jarrett Campbell
Did you tell it a joke?
Honestly I am glad you got it working!
Old Oct 24, 2016 | 07:10 AM
Jaaaaaaackman
Oh that should be jiggled ha oh man a potato head I are
Old Dec 27, 2016 | 12:34 PM
mcali2's Avatar
mcali2
what is the abs hub? the plug going to the speed sensor? pigtail?
Trevor.801
Jan 10, 2015 04:55 PM
snakedoc
Jun 24, 2011 04:15 PM
GALAZIO
Apr 24, 2007 08:38 PM
