ABS light on
Old Jun 23, 2011 | 09:44 PM
snakedoc's Avatar
snakedoc
ABS light on
the abs light is on so i repalsed the sensor on the rear end and the light is still on how do i find what is the problem. i have looked the front sensors and wires over and dont see a problem there. and AZ wonts $150 for the abs front sensors and im not going to buy it to see if it will fix it.
Old Jun 23, 2011 | 11:36 PM
SpringerPop's Avatar
SpringerPop
The first hint that a front hub bearing is going away on you is an intermittent ABS light.
Have you verified both front hubs are still running true?
Pop
Old Jun 24, 2011 | 12:10 PM
snakedoc's Avatar
snakedoc
i looked at them and had a shop look at them could not find a thing wrong.
Old Jun 24, 2011 | 04:15 PM
jwhitetail's Avatar
jwhitetail
There's a code stored that shows which wheel it is. Need a reader like Snap On etc. No AZ or regular code readers will read ABS.
Blue7.3
Australia Chapter
Feb 11, 2015 01:45 AM
mikulskn
Jun 26, 2013 11:23 PM
Forced347sn95
1997 - 2003 F150
Nov 15, 2008 10:12 AM
bronco5.8
1978 - 1996 Big Bronco
Jun 28, 2005 09:57 AM
bronco5.8
Aug 13, 2004 10:27 AM
