Living La Vida Bonehead
Recall I broke one of the injector connectors while replacing my oil cooler. Already waited a week for the new cooler to arrive. Then another week for the EGR delete kit. Putting it back together last Friday is when the connector broke. It was so tight, I bent one of the pins trying to connect the harness, although I couldn't see that in the tight confines of this #450, and it kept pushing the connector back into the engine. Then, the plastic broke as I tried to pull it back out over and over. Order a new one, pay for two-day deliver, it comes in three days today.
PITA to change out in this van, but I actually get it done without removing the injector. Discover the bent pin in the process and try to straighten it out with some needle nose.
Get it back together and try to push the harness on, but the same pin bends again. Try to squeeze it straight again with the needle nose...you know where this is going, right?
Pin breaks off. Now, I'm back to square one. I doubt the vendors will sell me just a pin. I'll have to pay another $25 for an entire connector kit (w/pins) to get a part that should cost about 25 cents, then wait another week for it to come in. Then go through the whole PITA process again.
Since this is a family site:
They may even repair the plug for you. If not. Ask for a pin extraction tool. With the tool, you can push the pin back through the connector and remove the broken one.
There is one catch, after you cut the old one off, the wire may be to short or you may have to remove the other two and re-pin them as well. The pin crimps onto the wire after you slide the copper into the pins backside.
Then push the repaired pin into the connector, it should almost snap into place. A light tug will be needed make sure the pin is fully inserted into the connector. GO EASY, don't ham fist it, don't yank it out the back... just a nice tug to make sure it's in there. You don't want it to back out when sliding them together.
Should be under the $5 limit.
And for God sakes... get a light on your work!
Oh , very good description you gave on how to rebuilt the connector.
Here is the plug removal and replacement video. It's uploading
right now so it may take a little bit to finish.
There was someone on Ebay that was selling the coils with the plug.
I found the item but can't get the Ebay to load on the computer and the
stupid tablet version of Ebay does not show you the item number. So you will
have to do the search or wait till I get some of the stuff I am uploading to
Youtube done. I seemed to have used up all my bandwidth.
Search for :
Ford Powerstroke Injector Solenoid Plug Kit (3052) New OE Injector Solenoid
That search should get you what your looking for.
Got the Auction Item Number for you >>> 171820064463
Hope that helps you out.
Sean
6.0L Tech Folder
