Sponsored by: Real Truck
Bad hub
Old Oct 20, 2016 | 10:17 AM
JoshC017's Avatar
JoshC017
Bad hub
On my 05 350, I noticed the other day that my 4wd wasn't working, when I needed it of course. I quick test this morning and I discovered my PS hub is not locking in. I've read a lot of posts about it being the opposite, the auto portion causing a problem. In my case, it won't lock in in auto or manually turning the ****. I can lock it in, spin the wheel and the axle shaft isn't turning. The pressure on the **** is the same as the other side, not too loose or too stiff. Can I pull the hub assembly off and rebuild it? I watched a video about that, but not sure on how my issue would allow me to work on it.
Old Oct 20, 2016 | 11:48 AM
seville009's Avatar
seville009
Are they the original hubs? If so, you can pull them off and clean them up/regrease them. Kind of sounds like something may be broken though.
I replaced my 2006 F350 Ford hubs a few years ago with Warn premium manual hubs (I always manually lock my hubs during the winter anyway); was a piece of cake, and I'm no mechanic.
Old Oct 20, 2016 | 11:50 AM
Sparky83's Avatar
Sparky83
i agree with seville.. sounds like something has broken in there if its not locking even when done manually...
Old Oct 20, 2016 | 12:06 PM
JoshC017's Avatar
JoshC017
yep, original. I'll pull her off this weekend and see what the heck broke. MONEY PIT!
Old Oct 20, 2016 | 12:09 PM
Sparky83's Avatar
Sparky83
if the auto hubs are made the manual ones.. its probably due to the plastic parts that are in there..
mad_science
Jan 29, 2018 09:57 AM
etk
Nov 21, 2011 05:43 PM
Estam
Apr 20, 2009 09:18 AM
pmasley
39
Oct 16, 2008 02:00 PM
Shovelhead 93
Nov 19, 2007 05:52 PM
