Brake Swapping Questions
Old Sep 27, 2015 | 08:15 PM
grinnergetter's Avatar
grinnergetter
K, this is what I'm working with...79 F250 4x4...everything brake related is new and NOT leaking as far as I can tell.
I recently swapped in a 4 speed and used pedals from who knows what year.
The truck had previously got the dual diaphram swap..F350 I think. Brakes were simply awesome.
So... the booster rod is 1" short of making the hole in the pedal. I added a chunk of steel to the front of pedal and redrilled hole.
I have no brakes!!!!!
After lots of thinking I decide to extend the adjusting rod under the master cylinder. After about 5 tries I get brakes(kinda spongy compared what I had before)
I measure the throw of the booster adjusting rod which there is 3/4" from pedal up to pedal bottomed to floor.
I finally ended up kinda "preloading" the master cylinder about 3/8 to get brakes.
Seeins how this is about stopping, I'm wondering what you think of this.
Am I right or do I need to start over? Is there a better way?
Old Sep 27, 2015 | 09:20 PM
PA74F250's Avatar
PA74F250
The brake pedal and booster combos sure can be a mystery can't they. So when you had the pedals out did you compare them with the ones you swapped in?
This may sound dumb and there may be another way to figure out the correct length. I would put the old pedal in that you say had awesome brakes and hook it up. Then slide the master cyl off the studs. I would take a measurement of the rod inside the bore of the booster where it enters the mc. Then put your new rigged up pedal in and see if it finishes close. Probably should cycle the pedal and take a measurement too with both out there at the booster. That's the only way I can think of what is causing the change.
1978fordf250
Sep 10, 2021 07:46 PM
Rusty_S
Oct 1, 2016 11:34 AM
91dirtydiesel
56
Jan 23, 2010 06:02 PM
dantsg
1997 - 2003 F150
Jul 27, 2008 05:04 PM
jenkinsj
Jun 20, 2008 08:08 AM
