Engine codes
Old Oct 19, 2016 | 07:08 PM
csmith30005's Avatar
csmith30005
Engine codes
If anyone can please help me interpret these engine codes.
Thanks in advanced
23 TP/FIPL sensor out of range
14 Profile Ignition Pickup PIP Erratic
29 Open vehicle speed sensor
59 LO-Fuel pump ckt open/2-3 shift error
67 PNP or clutch switch ckt failure
Old Oct 19, 2016 | 08:43 PM
Macrobb's Avatar
Macrobb
Um... year of truck? Are you sure you have an IDI? IDIs have no engine computer, though the E4OD has a /transmission/ computer.
The Powerstroke(94-03) has an engine computer *and* transmission computer(with the automatic transmission)
Old Oct 19, 2016 | 08:49 PM
csmith30005
It is a 1993 7.3 and it does have an E4OD trans
Old Oct 19, 2016 | 09:11 PM
Macrobb's Avatar
Macrobb
In that case, they are transmission codes, not engine codes.
Um, I can tell you a little bit.
First off, the TPS/FIPL is the sensor that's attached to the driver's side of the IP, on the throttle shaft. It sends the throttle position to the transmission computer.
I'd check the wiring first.
Second, I'd check all the fuses.
I don't know much about the E4OD; hopefully someone else will chime in here with some ideas.
fishfreak101
20
Nov 13, 2023 12:49 PM
aclaybor
Feb 3, 2017 01:32 PM
erbear69
Aug 25, 2016 08:27 PM
ZonaNavyStar
Feb 3, 2007 07:10 AM
reddevilf150
Jul 28, 2003 03:27 PM
