First oil change
Old Oct 18, 2016 | 12:51 PM
DeputyDiesel's Avatar
DeputyDiesel
First oil change
My dealer said the first oil change is free but never told me what mileage ford recommends for the first change. Any ideas?
Old Oct 18, 2016 | 01:01 PM
Kenv's Avatar
Kenv
Some say 5000 for the first....some say 7500...some say wait until the dash tells you. I do 5000 for the first and 7000 every one after that. I don't haul heavy frequently though.
Force74's Avatar
Force74
I'm doing mine at 5000 as well.
Old Oct 18, 2016 | 01:07 PM
EpicCowlick's Avatar
EpicCowlick
I'll do it at 5,000 and then whenever the truck tells me to.
Old Oct 18, 2016 | 01:22 PM
Kdr358's Avatar
Kdr358
I have always done the 1,000 mile break in period, then had it changed and resumed with 5k intervals
Old Oct 18, 2016 | 01:44 PM
msdt-99517's Avatar
msdt-99517
Bro in law is a ford diesel tech and he says they recommend 5k due to break in oil. But he also says 7500 to 10k is fine. If you tow over 10k 3-4 k miles he says to change every 5-6k. Just his 2 cents not sure if it's true.
Old Oct 18, 2016 | 01:47 PM
HouseMouse's Avatar
HouseMouse
Just had mine done today at 5000 and the rest will be as you say.... "Whenever the truck tells me to".
System's Avatar
System
Prolocutor
I'd do my first at 1k when I'm ready to tow to get the dino 10w30 out of there and get some proper Rotella T6 5w40 in. Then every 5k to keep it easy.
Old Oct 18, 2016 | 05:39 PM
invstr55's Avatar
invstr55
I did my first one at 1000, changed to full synthetic and discovered that owners manual is wrong.. still takes 13 quarts.
Old Oct 18, 2016 | 05:57 PM
TrikeDawg's Avatar
TrikeDawg
Which oil did you change too? Do you have the typewriter clicking sound now?
Old Oct 18, 2016 | 06:07 PM
vitacura's Avatar
vitacura
I put about 5k miles on my truck per year.. so once a year for me.
Old Oct 18, 2016 | 06:09 PM
HouseMouse's Avatar
HouseMouse
Dealer changed the oil....10W-30 Diesel Oil. 13Qts. All info comes from the invoice.
Old Oct 18, 2016 | 07:56 PM
Azuretruck's Avatar
Azuretruck
Is the full synthetic more expensive? Does the dealer provide oil or did you?
Old Oct 18, 2016 | 08:07 PM
Tomc750's Avatar
Tomc750
There is still break in oil? Kinda thought that was a thing of the past. If so, other than lighter visc., wonder what it is. Break in is very interesting subject - a whole separate treatise.
Old Oct 18, 2016 | 08:11 PM
System's Avatar
System
Prolocutor
The dealer likely won't provide 5w40 as a free first change. Do it yourself. It's not worth the trip to the dealer to get 10W30 for free. T6 is $21 a gallon at Walmart. The Motorcraft filter is $15 on Amazon. The oil change itself is one of the easiest you can do. What makes the second change even easier is to change out your drain plug for an EZDrain valve. Makes changing a no mess deal. Use a piece of tubing to drain the oil right into empty oil jugs and you won't even need an drain pan. For the filter, take a large screwdriver or hole punch and punch the filter before threading it off and it will drain right into a pan. Otherwise, the oil will run down the sides and make a mess. Here's a link to the EZ drain valve and the tube extension.
https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER
