First oil change
Old Oct 19, 2016 | 01:32 PM
  #46
Rasalas's Avatar
Rasalas
Originally Posted by Karl4Cat
Rob, the valve is tougher than the oil pan it's screwed into. It's far more likely you put a rock through your oil pan than to knock off a horizontally mounted valve that's above the very bottom of the pan. In other words, if something is going to get you, this ain't it...
Maybe the orientation of the drain plug has changed from the bottom to the side of the pan. But in past years having a valve stick down 1 inch below the bottom was a sure target. Thanks, Rodney for the information. I agree that off the side is a much more settling.
Old Oct 19, 2016 | 01:39 PM
  #47
System's Avatar
System
Prolocutor
Yep, on the 6.7's the drain plug faces straight back. This makes for a huge mess without the valve as with 13 quarts of hot oil pushing, it can really get some distance!
Old Oct 20, 2016 | 08:11 AM
  #48
Rasty1's Avatar
Rasty1
Thanks for the sites on the EZ drain valves! I love these things, sure makes changing oil a snap!
Afrnd2all
Nov 16, 2017 11:41 PM
CollinsCD
Aug 19, 2015 09:17 AM
GeneLaw1
Aug 31, 2011 01:09 PM
White Knight 2011
6.7L Power Stroke Diesel
Sep 11, 2010 03:44 PM
gregarobinson
2004 - 2008 F150
32
Dec 15, 2004 03:06 PM
