Sponsored by: Kumho
$35 Electric Power Steering with Fail-Safe - 3 Wire hookup & No eBay module!
Old Oct 16, 2016 | 04:16 PM
waid302's Avatar
waid302
It has been a while since I posted on this forum. I am not making or selling anything. I have posted this on couple of other forums and this is not for everyone.
Some of you have manual steering and I though you might like to see how added electric assisted power steering in my 1964 Falcon. Some of you may have come across the Saturn Vue conversions but I think I have found even cheaper and better alternative with no caster issues!
My testing shows that most Japanese branded cars and SUV with electric steering works in Fail-Safe mode if the control unit (ECU) is disconnected from CAN BUS. The effort in Fail-Safe mode feels just right like my 2013 Honda Civic. Not too much and not too little. Just like Hydraulic Steering, if the Electric Assisted Steering completely fails, the steering is back to completely manual mode maintaining car control.
The biggest advantage of using EPS from Toyota, Nissan and Kia/Hyundai is that the EPS works in Fail-Safe. The ECU for the column is mounted remotely and cab be disconnected and removed. The EPS from Saturn Vue and Chevy Cobalt has the ECU that cannot be disconnected and must be de-soldered for remote mount. More importantly there is no Fail-Safe and a 3rd party eBay module is needed in order for it to work. Additionally , people have reported that with after market eBay module, the Saturn EPS does not self center the steering wheel coming out of a turn. You have to make constant corrections.
Below is the list of Car that I know of that has Fail-Safe Electric Steering. Only 3 wire connection. Ignition On, Power and Ground to the Steering ECU. That's it !
2004-2009 Toyota Prius
2009-2013 Toyota Corolla
2006-2011 Toyota Yaris - (With ABS)
2007-2009 Nissan Versa
2009-2012 Nissan Cube
2012-2014 Kia Soul
ECU Part Numbers:
2004-2009 Toyota Prius 89650-47102
2009-2013 Toyota Corolla 89650-02300
2006-2011 Toyota Yaris - (With ABS) 89650-52120 / 52050
2007-2009 Nissan Versa 28500-EM30A / 991-30303
2009-2012 Nissan Cube 28500-1FC0B / JL501-000932
2012-2014 Kia Soul B2563-99500 / 4PSG1312 / FPSG1312
The output shaft on Toyota is little larger than the rest and therefore the Borgeson 312500, 11/16 36 X 3/4 smooth bore weldable coupling should fits nicely. This couple fits the others as well. The Kia EPS is the biggest and appears to be most heavy duty. The Prius & Corolla EPS are very easy to find at salvage yards so this is the best bet. I picked up these EPS for testing for $35 each at my local pic-a-part
Note: As with any modification, there are risks. This post is intended to show how I did my modification. Use it at your own risk!
Waid
Old Oct 16, 2016 | 04:17 PM
waid302's Avatar
waid302
General Information
Old Oct 16, 2016 | 04:20 PM
waid302's Avatar
waid302
My upper steering shaft and column tube modification
Old Oct 16, 2016 | 04:21 PM
waid302's Avatar
waid302
I first did the mod with Steering box. Later I removed it and went with Rack and Pinion.
Old Oct 16, 2016 | 04:23 PM
waid302's Avatar
waid302
For car/trucks with collapsible steering column.
Old Oct 16, 2016 | 04:26 PM
waid302's Avatar
waid302
This his how I did my Rack and Pinion
Old Oct 16, 2016 | 04:27 PM
waid302's Avatar
waid302
Wiring Diagrams. Only 3 wires are needed. Power, Ground and Ignition On
Old Oct 16, 2016 | 04:28 PM
waid302's Avatar
waid302
YouTube Videos:
DIY Electric Power Steering 1 - EPS with Fail Safe
DIY Electric Power Steering 2 - Bench Test
DIY Electric Power Steering 3 - Mounting Options
DIY Electric Power Steering 4 - In Car Test
Old Nov 2, 2025 | 10:45 AM
Pyobluebonus's Avatar
Pyobluebonus
4th Gear
Wiring
[I have a kia soul Unit and wired it to the battery with the main power and 12 to terminal 1 in modular plug solder to terminal 1. Not sure what is wrong it will not work any help would be greatly appreciated.
QUOTE=waid302;16650501]It has been a while since I posted on this forum. I am not making or selling anything. I have posted this on couple of other forums and this is not for everyone.
2012-2014 Kia Soul
ECU Part Numbers:
Waid[/QUOTE]
Old Nov 2, 2025 | 02:51 PM
xlt4wd90's Avatar
xlt4wd90
I've been very interested in this kind of conversion for my1969 Mustang.
Just to verify, the Kia setup provides the power assist to the steering shaft?
I found an electric rack and pinion setup for a 2003 VW Jetta which works a little differently. It has a torque sensor at the base of the shaft where it goes into the pinion of the R&P. That is picked up by some electronics on the motor, which is mounted on the other end of the rack housing, and has a CANBUS connection to the drivetrain computer. The motor drives a gear through a rubber isolater, which then drives a gear on the rack. I prefer this design, since it applies the assist more directly to the rack.
Unfortunately, I could not figure out how it works, nor did I have a drivetrain computer for it to talk to. I saw on some VW forums how sophisticated that EPS was, and realized I had no idea how to get it to work, so I eventually gave up on it.
But in the process, I did upgrade the stock alternator to a 3G version that supplied twice the current, in anticipation of needing a lot more current to operate the rack; it had a 90 amp fuse in its power line. And I replaced the stock starer motor with a compact PMGR version, in anticipation of needing more space in the area for the power assist motor.
I ended up replacing the stock steering system with a R&P setup from Unisteer.
https://photos.google.com/share/AF1Q...ZEOUVmWjRfSFl3
Please provide more information (pictures if possible) on your conversion.
thanks
rustygreen76ford
43
Apr 21, 2024 09:13 AM
ireding
Jan 5, 2017 08:35 AM
Ranchero_Boy
Feb 2, 2014 08:03 PM
Caleb H
Jan 2, 2012 10:50 PM
Lucannus
Aug 5, 2004 02:50 PM
