Sponsored by: Kumho
Sinking brake pedal only with engine running
Old Nov 10, 2025 | 07:41 AM
gitane59's Avatar
gitane59
2020 Superduty F250 6.7 diesel with vacuum brakes. With engine running brake pedal is low at initial application of brakes. Pumping pedal gentle brings it back to normal level, but if you hold the brake pedal on at this moment the pedal slowly sinks back down almost to the floor.
With engine off, after pressing the brake pedal to release the vacuum from the booster the pedal is firm and their is zero abiltity to pump the pedal level up.
Just had truck inspected about 6 weeks ago and the brakes passed the inspection check, Brake fluid level is fine and there is no slow leaks anywhere.
How do I diagnosed this brake issue further without throwing parts at it?
Old Nov 12, 2025 | 03:17 PM
beartracks's Avatar
beartracks
I think it's your vacuum booster but not familiar with late model.
Old Nov 12, 2025 | 04:31 PM
tjc transport's Avatar
tjc transport
i ain't rite
it could also be a bypassing master cylinder, but i doubt a 2020 would be bad already.
Old Nov 17, 2025 | 10:34 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
I'd guess a bad master as well. Surprising on a 2020. Does it have a lot of miles on it?
sd ford
2023+ Super Duty
Sep 18, 2025 04:56 PM
eriksf250
23
Jun 18, 2022 12:03 PM
Nealcrenshaw
Jan 23, 2015 05:31 PM
myfeetrock
Jan 22, 2015 09:55 PM
Torstein
Apr 27, 2003 04:20 PM
