First time for everything
Old Oct 19, 2016 | 07:18 PM
04badford's Avatar
04badford
Originally Posted by Rusty Axlerod
Important info on that trans filter, that thing can be hard to get off. It gets pretty stuck on there over time and the bracket is flimsy. If you try to gently remove it the bracket bends. If compressed air is available, an impact wrench is the best way to get it off, other options are to use a tie strap to help support it while breaking the filter loose or pull the whole assembly off the truck and chuck it up in a vise.
Good point Eric , it has to be a 6 point 22 mil socket on a impact
Old Oct 20, 2016 | 04:43 AM
Yahiko's Avatar
Yahiko
You don't want to fill with premixed coolant. You want the concentrate.
You can then later use the premixed for topping off.
If you don't them the distilled water that you used for the rinse will
dilute the coolant too much.
Sean
6.0L Tech Folder
Old Oct 20, 2016 | 10:27 AM
lanneinbc's Avatar
lanneinbc
Originally Posted by lanneinbc
I can get a good deal on the Cat ELC pre-mix for later on, so I'm going to replace the current whatever-it-is with the Cat concentrate and distilled water.
DH drives a logging truck and his company buys the Cat premix in bulk. We can get it at their cost, but that really doesn't help for the initial change-over.
I called the local dealer and they only stock the premix, but a bigger city north of us carries the concentrate. Local guy said they could have it shipped here but it would cost an extra $12.50 per gallon! My neighbour works up there so he's picking it up for me today.
Old Oct 20, 2016 | 10:52 AM
Rusty Axlerod's Avatar
Rusty Axlerod
More details.
Total cooling system capacity including the degas bottle is 27.5 qts. If you drain the radiator by the lower hose or the draincock you'll remove 1/2 the system capacity--about 14 qts. Therefore it takes 14 qts of 100% coolant added back to the system to get a 50/50 mix if you do a complete flush and fill.
kawasaki150hp
Aug 20, 2018 02:39 PM
insolution
16
Jul 24, 2014 04:38 PM
95PSDieselP
May 24, 2012 08:00 AM
GR8NW
Jan 20, 2010 05:02 PM
Pele
Jan 16, 2007 06:52 PM
