WatsonR was correct...brand new stand pipe on driver's side with damaged o-ring. Mechanic leak tested again and it passed 10 min test but failed 30 min test. Looks like they only went 10 minutes before clearing her after replacing HPOP.
Guess i had one of the "rare failures"...from what I've read on internet, for 05-07 they work or don't work.
Pulling 5th wheel back to Texas from Colorado seemingly no issues. Stopped for lunch in Wichita Falls for 1.5 hours and then crank, no start (insufficient ICP pressure). No pressure leaks when performing pressure test from IPR fitting.
