HPOP trends
Old Oct 15, 2016 | 03:14 PM
BjornF16's Avatar
BjornF16
HPOP trends
Just dropped coin on a HPOP replacement on my 2006 F-350. Coming home to Texas from CO pulling my 5th wheel. Everything seemed fine until we finished lunch and tried starting in Wichita Falls. Crank, no start. FICM and sync were good. Not producing pressure. STC fitting not leaking.
My truck just surpassed 153,000 miles.
Wondering what is the typical life of HPOP on these 6.0's...
Old Oct 15, 2016 | 03:22 PM
navistarnut's Avatar
navistarnut
The late builds rarely have the HPOP fail, so you are among the few. I do hope they replaced the STC whilst they had things torn apart that far for a $50 kit.
It's not unheard of for late builds to have the HPOP replaced as part of an incorrect diagnosis.
Old Oct 15, 2016 | 03:30 PM
BjornF16's Avatar
BjornF16
I interrogated the shop owner...he was very knowledgeable on the 6.0's. He said they checked the STC and piping for leak to verify it was indeed the HPOP (after eliminating other possibilities). I could only verify I was not building pressure when cranking.
I was surprised it would fail so suddenly, but in thinking back on pulling up Raton Pass, I thought she was ******* on me some.
Old Oct 25, 2016 | 01:50 PM
BjornF16's Avatar
BjornF16
Another good talk with shop owner in Wichita Falls...really knows his stuff and has solid reputation.
In addition to HPOP, they replaced: STC fitting, tubes, dummy plugs and IPR valve. Filled with Rotella T.
Now notice extended crank when cold with successful start (didn't have that issue before HPOP went out).
Motorcraft 650 batteries nearing 3 years. I was going to have them tested. Also preparing to do battery ground mod.
Any other suggestions to resolve cold extended crank?
Old Oct 25, 2016 | 02:13 PM
run6.0run's Avatar
run6.0run
The replacement pump comes with the updated fitting installed. Anything is possible,, but I've yet to fix an issue by replacing the pump in a late model. As of now,, it's ALWAYS been something else. But hey,,who knows
WatsonR's Avatar
WatsonR
What is the FICM output reading?
Old Oct 25, 2016 | 02:18 PM
BjornF16's Avatar
BjornF16
FICM reads 48.5v when running...iirc, it was approx 46-47v when cranking (when SGII started reading).
Old Oct 25, 2016 | 02:22 PM
FiznUKa's Avatar
FiznUKa
What is your ICP pressure and IPR% while cranking.
Old Oct 25, 2016 | 02:28 PM
BjornF16's Avatar
BjornF16
ICP > 500 psi; IPR% ~ 45%...but SGII doesn't register everything immediately so I'm not sure what is "lagging", ICP or FICM volts. All subsequent starts are normal.
I'll perform another start using SGII and record it.
Old Oct 25, 2016 | 02:33 PM
6.0only's Avatar
6.0only
Did HPOP ingest trash?
Old Oct 25, 2016 | 02:36 PM
BjornF16's Avatar
BjornF16
Don't think so...I talked with mechanic who did work. No other issues noted, IPR screen intact, compliments on how well the truck maintained .
Extended crank/start only on first cold start attempt. All others normal start (i.e. I start it with extended crank, shut down and restart). Warm starts not an issue.
Old Oct 25, 2016 | 04:48 PM
BjornF16's Avatar
BjornF16
Just started after 3 day sit in Texas...after watching video I see that IPR% jumps to 85% after cranking, with ICP sitting low. ICP on SGII doesn't jump up >500 psi until after it has started.
https://dl.dropboxusercontent.com/u/...G_1504.MOV.m4v
Old Oct 25, 2016 | 04:49 PM
WatsonR's Avatar
WatsonR
Turn the key on, while waiting on the WTS light to go out, key the Scan Gauge. It will come on and show pre-start numbers.
Old Oct 25, 2016 | 04:52 PM
WatsonR's Avatar
WatsonR
It needs 500+ to start... why it's slow to fire. You sir... have a leak and need to air test the system to find it. Most likely dummy plugs. If it was the STC fitting. It wouldn't fire at all.
Old Oct 25, 2016 | 06:23 PM
BjornF16's Avatar
BjornF16
Well...mechanic said they leak tested at the IPR with air before clearing her.
I do have two bad batteries (just confirmed) that I'll replace tomorrow. Both Motorcraft BXT-65-750's replaced back in Jan 2014 (so looks like I should get two free batteries).
