Manual Transfer case Shifter
Old Oct 13, 2016 | 06:18 AM
fishfreak101's Avatar
fishfreak101
On my 97' F-250 I am able to shift between 2h and 4h (both work well) but I am unable to shift between neutral and 4l. Ive been spraying the linkage with lots of penetrating oil. Any other ideas?
Old Oct 13, 2016 | 07:41 AM
jas88's Avatar
jas88
Replace entire assembly with the older style (thru 1991 I believe) linkage. Otherwise you will need to remove your shifter and take it apart to clean up where it is seized and put a grease fitting in the housing to keep it lubed up.
Old Oct 13, 2016 | 08:08 AM
Da_Lariat_Chariot's Avatar
Da_Lariat_Chariot
If you disconnect the linkage from the case, does it still bind up? There could be an issue inside the case itself.
Old Oct 13, 2016 | 11:41 AM
fishfreak101
Don't know I'll try that when I get home. If the transfer case isn't the issue what would you suggest in order to fix the shifter?
Old Oct 13, 2016 | 12:06 PM
madpogue's Avatar
madpogue
Does the shifter move up and down (not forward and back, but _up_ and _down_) in 4HI, and does it allow you to go from 4HI to neutral when you push it down? If so, does it come back up when you get to Neutral?
Old Oct 13, 2016 | 12:24 PM
fishfreak101
The shifter really doesn't move except forward and backwards between 2h and 4h. The spring compresses a little when I push downward while in 4h. The shifter doesn't go into N.
Old Oct 13, 2016 | 12:26 PM
Fastback460's Avatar
Fastback460
You may already know this but it hasn't been mentioned yet.
The transmission has to be in neutral in order to shift into 4Lo. Put the truck in neutral, shift the t-case into 4HI, push down and then pull back on the shifter.
Old Oct 13, 2016 | 12:29 PM
fishfreak101
I've tried doing it when the truck is in neuteral before. But isn't it the same as park. Ive tried both.
Old Oct 13, 2016 | 12:36 PM
madpogue's Avatar
madpogue
Slide under the truck and have a buddy operate the shifter. You'll see how the pin and lockout plate interact. Pay close attention esp. when your assistant does the "push down" part in 4HI; see if the shifter moves down far enough for the pin to clear the blockout plate. If it doesn't, there's your trouble; the up-down action on the linkage is stuck. Common issue with these shifters. "Nuclear" option is to cut the pin off so it doesn't have to clear the plate. Some fellas have drilled into the side of the linkage and inserted a zerk fitting and lubed it to get the up-down action working again.
Old Oct 13, 2016 | 07:40 PM
arse_sidewards's Avatar
arse_sidewards
Remove the shifter, clean, lubricate and reassemble. Grease fittings are optional but won't hurt. It's not like you need to service it more then about once every decade and a half anyway.
I'd just like to point out that replacing it with the old style is as much or more work than removing, repairing and adding a grease fitting to the current one and is significantly more expensive.
Old Oct 14, 2016 | 11:00 AM
fishfreak101
The up down action on the lever is not working. I am considering cutting the pin off like you had mentioned. Would you advise against that?
Old Oct 14, 2016 | 11:34 AM
Nothing Special's Avatar
Nothing Special
No, I think it has to be in neutral, not park or any of the driving gears (not that this helps you since it doesn't work in neutral either...)
Old Oct 14, 2016 | 12:20 PM
Diesel_Brad's Avatar
Diesel_Brad
Here, have a read
https://www.ford-trucks.com/forums/1...er-repair.html
Old Oct 14, 2016 | 12:22 PM
Diesel_Brad
If you remove the detent pin, you can cause some Serious problems.
When pulling back to shift from 2wd to 4wd his, you can go straight to 4wd Lo and that would be Bad, ESPECIALLY if moving
Old Oct 14, 2016 | 08:05 PM
arse_sidewards
Losing idiot proofing isn't that big of a deal. Every 80s truck had shifter that was just a straight lever.
