Transmission Cooler options
Old Oct 10, 2016 | 09:37 PM
Slyhuntr's Avatar
Slyhuntr
We have ordered our first 5th wheel RV, now I am thinking I may want to upgrade the tranny cooler? Our TV is the 01' 7.3L with the 4R100. What are my options fellas?
Old Oct 10, 2016 | 09:41 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
There are a lot of options. In my opinion the best option is to scrap the air to oil cooler that came with the truck and replace it with one from a 2003-2007 6.0L truck. The routing is from the front of the trans to the radiator cooler, from there to the 6.0L cooler, and from there back to the rear of the trans.
Old Oct 10, 2016 | 10:00 PM
Chipworkz's Avatar
Chipworkz
To add to what Mark said, here is the part you want.
26 row transmission cooler
On my e99, I added this cooler along with the 2004 radiator 4C3Z8005EB
to get the OTW cooler as well.
Here are a couple of pictures of the new lines.
Drivers side
Passenger side
Old Oct 11, 2016 | 06:41 AM
pirschwagon's Avatar
pirschwagon
To add what the others have stated with a Caveat, The 6.0L Cooler is an excellent choice, along with REGULAR maintenance.
CAVEOT:
Any quality "Stacked Plate Cooler" is going to out perform your stock cooler. Not because your stock cooler is a poor design. But, because it's OLD; blockage, debris, poor maintenance, etc. all have negative effects.
I have a Doral Brand and can pull #8,500 lbs. and not see above 180* - 190* on a 100* day. When I stop it does get to 200*+ after pulling for a few hours. Don't just turn it off when this happens, an increased Idle for 10 minutes will drastically lower the temperature and allow the fluid to carry heat away from critical components and drops temperatures below 170*.
Fluid is much more than a lubricant and pressure generator. 200,000 miles and my transmission is in excellent condition towing regularly and performing maintenance (Just jinxed myself).
Old Oct 11, 2016 | 08:35 AM
Big Black Dually's Avatar
Big Black Dually
Great Information
Chipworkz,
That is some great information and thanks for taking the time to put the links in your signature.
Thank you,
Big Black Dually
Old Oct 12, 2016 | 05:15 AM
Slyhuntr's Avatar
Slyhuntr
Thank you Chipworkz, awesome information.
Old Dec 16, 2016 | 03:32 PM
tofer76's Avatar
tofer76
to add to others i have a 2000 sd 7.3l and i went with the 6.0l cooler love it!
my trans temps dropped 40* average. was easy to do(take off the front bumper) and my cts monitor shows a 40* diff to the eot now instead of 5*
Old Dec 16, 2016 | 05:33 PM
dn29626's Avatar
dn29626
Like the drawing and pictures.
Old Dec 17, 2016 | 10:46 AM
machmedic's Avatar
machmedic
Put a 6.0 cooler on mine and it made a big difference, how much does your 5th wheel weigh?
Old Dec 17, 2016 | 11:45 PM
Slyhuntr's Avatar
Slyhuntr
Sticker on side of trailer states 9800# dry. I haven't had a chance to take her over a scale yet.
Old Dec 18, 2016 | 02:54 AM
Michael 7.3Power's Avatar
Michael 7.3Power
Another vote for the 6.0 cooler.
I have a 2002 f350 and I'm towing gear to my weight rating and sometimes a little over and it never gets too hot.
SoCalAngler
Aug 13, 2020 10:52 PM
95copperhead
17
Feb 18, 2019 09:48 PM
Phoenix02
May 25, 2018 03:48 AM
GerritMaxwell
19
Feb 15, 2016 07:50 PM
tnwill
Oct 26, 2007 04:35 PM
