Hi all,
The original trans cooler I believe has significant room for improvement.
We do a descent amount of stoplight to stoplight towing in the desert region.
Just deciding how to go about this.
Option A- remove and replace original cooler with larger newer (better design stacked plate/fin) cooler.
Option B- splice in another additional cooler while still using original.
Option C- remove original and replace with remote(electric fan style) cooler.
Anyone have any experience and results with sharing? Thoughts, ideas?
Is option A significant enough?
Option B just seems like a truck load (pun intended) of work to set up nicely.
Is option C, overkill? thought it would be good to put it on the thermostat, or toggle switch to flip on and off during traffic and heat. Plus maybe extra draw through radiator.
Thanks,
Gerrit
The radiator cooler is the most efficient cooler in the package. Don't replace it, you lose a lot of cooling capacity.
In my opinion, formed from working as an automatic transmission cooling engineer for the last three years of my career at Ford, I recommend option A. And the cooler I recommend is one from a 2003-2007 6.0L F-Series truck.
Are you having transmission problems or is it just something you want to do for the truck. When you do the job I would hard plumb it. Rubber hose works for a while but always seems to end up leaking.
i always recommend buying a trans temp gauge first.install @ the test port.
if your getting higher than 225F there,then it's time to upgrade your cooler.if your not ever seeing over 225F your running good.
the E4OD trans cools very easy.it's the 4R100 with it's pump that doesn't flow so much (for efficiency increase) when the trans converter locks.the e4's pumps like a bugger.especially the '95+
Originally Posted by Briansshop
I have 2 B&M supercoolers, one with a fan,on my 350. I do not use the radiator cooler.
your missing out on max cooling efficiency.aux air coolers can't compete with the water cooler.
Over the years, I've read about leaky rear main seals, torque converter shudder upon lock-up and fuel tank cross-flow issues. But I have yet to read about the mass amounts of owners having issues with engine coolant getting into the transmission. Not saying it doesn't happen, but I just haven't seen it here, or on the other Ford truck forums I visit. I've had many Ford trucks, with automatic transmissions, and never had an encounter with a trans/engine coolant breach, or read it on other Ford truck forums that I frequent.
You posted the same comment there. Also some posts from a guy that is a respected trans builder that recommends bypassing not only because of potential leakage, but because of clogging and restricting pump flow.
Just the fact that it's possible is enough to convince me. Trans is too expensive to chance it.
I say your risk of overheating the trans from the air-oil coolers not getting enough air-flow is far higher than the in-tank cooler failing. Literally almost every single automatic transmission vehicle built in the past ~40 years uses an in-tank radiator cooler. If it were a huge problem, you'd see about it a lot more.
I've seen more transmissions burnt up from bypassed radiator coolers than I've seen radiator coolers plug or leak.
run it both ways, ive run them without and with radiator and always run a temp gauge didnt notice much difference, other then when i had it going thru the radiator the engine overheated and took out the transmission also.
No risk of overheating mine. Both trucks have trans temp gauges and for the way I use the trucks, as I stated earlier,I have no trans cooling problems.
I admit it's not for everyone,and for the average driver the rad cooler is better. Just isn't for me.
this is the case,by a landslide.it's when the truck isn't always moving when them temps coming out of the converter can really heat up.
sure,an electric fan can help,but your really risk your trans.i wouldn't leave the vehicle sitting unattended while parked idling and i wouldn't let my guard down about watching the temp gauge.id also have two gauges,one to monitor the test port and another the converter outlet.
the risk to reward simply isn't there,to not run though the radiator.basically because it's all risk and no reward anyway.
it's your truck.run it how ya want.but you owe it to yourself to acknowledge the fact that you have an increased risk of overheating your trans.knowing this,you'll be more prepared to keep an eye on things better.don't ever lend the truck out.
