Installing boost gauge question
Old Aug 22, 2003 | 04:28 PM
Thumper4995's Avatar
Thumper4995
Question Installing boost gauge question
I have a question about installing the "T" fitting for the boost gauge. I am sure I am doing something wrong but I insert the black boost line from the gauge into the brass fitting (that screwed onto the nylon "T" and when I tighten the brass nut down, the boost line still slides out.????. Am I not tightening it enough? I don't want to crush anything......any ideas???
Old Aug 22, 2003 | 05:00 PM
Thumper4995
Well, I layered the boost line with some teflon tape for a temporary fix. Is there supposed to be some sort of a adapter that goes on the boost (I think it is also called a capillary) line prior to being inserted into the brass fitting??
Old Aug 22, 2003 | 05:06 PM
theologian's Avatar
theologian
On mine there is a small brass tube, that fits the capillary tube snugly. When screwed tight, it holds well.
Theo
Old Aug 22, 2003 | 11:41 PM
elkhunter2's Avatar
elkhunter2
Normlly there is a brass tube that fits inside the plastic / nylon tubing. The brass tubing supports the plastic tubing when the nut is tightened down.
Old Aug 23, 2003 | 06:56 AM
Calli's Avatar
Calli
Thumper, there are two parts to the compression nut. First slide the compression nut on the line and then slide the compression ferrule, which is a tapered tubelike part, on the line. It fits inside the compression nut. Very small, check your package good. Can probably be found at hardware store. Good luck, Carroll Allison
PJ-Hunter
Mar 17, 2016 12:13 PM
andym
Mar 31, 2015 06:02 AM
Bluey Zedoff
29
Mar 29, 2015 09:16 PM
f350ford17
Dec 9, 2012 10:40 PM
dieselstroke
Jun 8, 2004 09:34 PM
