Wernch Icon ???
Old Oct 9, 2016 | 08:02 PM
50th ann's Avatar
50th ann
Wernch Icon ???
A wrench Icon is intermittently appearing in the instrument cluster. This started on the way home right after I picked up up the truck from a transmission shop that replaced the torque converter. Not sure what one would have to do with the other.
The owners manual says the Wrench Icon indicates Electronic Throttle Control:
The engine has defaulted to a limp home mode. Report to the dealer at the earliest opportunity. Any ideas what this might be??
The truck seems to be running like it always has.
Old Oct 10, 2016 | 07:59 AM
ubereal2's Avatar
ubereal2
What is it?!
Old Oct 10, 2016 | 04:17 PM
50th ann's Avatar
50th ann
2010 F-150 Lariat Super Cab
5.4 L 2 WD Automatic.
170,000 MIles
Old Oct 10, 2016 | 05:07 PM
ubereal2's Avatar
ubereal2
First thing I would say to try would be to unhook both battery cables and wait about 30 minutes then reinstall, and see if that takes the truck out of limp mode. Then I'd see if the truck does the same thing. If it does, I'd have to see about getting to a good shop.
Unk Bob
Old Oct 11, 2016 | 11:01 AM
ford390gashog's Avatar
ford390gashog
Wrench icon is also used for transmission faults. Especially if the sensor is has detected slippage of the output. This can also be from a non functioning sensor. The sensors are mounted on top of the valve body and are prone to false readings with metal contamination. You mention a new torque converter and that means the old one failed are probably sent debris throughout the transmission.
bighunt34
2004 - 2008 F150
16
Nov 17, 2019 03:56 PM
TrailsEnd
Apr 13, 2009 12:40 PM
RJ's325ITS
1997 - 2003 F150
Dec 7, 2008 03:09 PM
Palaminomike
2004 - 2008 F150
Sep 20, 2005 07:54 PM
mhamFORD_FAN
2004 - 2008 F150
29
Mar 4, 2004 08:33 AM
