Who can help me?
Old Oct 9, 2016 | 09:04 PM
WhatsAChevy?'s Avatar
WhatsAChevy?
Sorry son, seems like you are all over the map on what you want to accomplish with your field find. In the immortal words of Hank Snow.....I'm movin' on....
Old Oct 9, 2016 | 09:14 PM
Anderson80's Avatar
Anderson80
Haha ok let me explain.... So in 2005 my dad bought it from a buddy. When we got it home he tinkered with it and got it running. It didn't run exactly right so he bought a 79 Ford F-150 with a 351w to swap into this one. They both got parked behind the barn in 2007 or 2008 and he never got around to the swap, since he was a truck driver he didn't have time.
Now skip to 2015, my mom and my stepdad decided to take it to our farm where we could use what we want for parts and scrap the rest. Well I didn't let that happen, I decided to go out there and get the plugs out and throw some atc and diesel into the cylinders just to see if I Could free the motor up. It's hard to find parts around here so I was asking around to see if you guys had an idea on getting the thing going.. We still have the 79 at my old house but it has a rare 200 dollar locking hood release with a frozen cable... I don't really want to cut the cable so it will keep its motor till I get that figured out.
Old Oct 9, 2016 | 09:54 PM
rowdyredneck's Avatar
rowdyredneck
While its certainly possible to get it running again, don't set your expectations too high. Seven years of sitting outside in the elements is pretty unforgiving. Condensation is the most likely culprit. Even if you do get the engine to turn over you might still be faced with seized valves. There's no way the gas will be any good after that long either so you'll have to drop the tank/tanks and clean everything out and I would expect the tanks to be coated with rust inside after that long. Don't be surprised if the brakes are seized up too.
Old Oct 9, 2016 | 10:05 PM
Anderson80's Avatar
Anderson80
Can't do much till I find the key... The brake caliper is being held onto the leaf springs by a bungee cord at the moment too... Might just skip the tanks if the motor will turn and mount a tank in the bed too. Opinions? The only rust is in the passenger side floorboard where we threw two bags of cement and held moisture.
Old Oct 9, 2016 | 11:03 PM
ctubutis's Avatar
ctubutis
My guess is the engine is rusted together inside.
But let's say you can break it free and get it to turn over. To get it to run, you're probably going to want/need to replace the fuel system - tanks, pump, carburetor - as the tanks & sending units could very well be full of rust, the rubber parts in the pump & carb are probably going to be dry-rotted.
But say by some miracle you get it to run... expect it to burn oil heavily.
A 351W won't bolt up to the existing transmission (different bell housing bolt pattern) nor are the engine stands (what the engine mounts attach to) the same. Furthermore, none of the accessories (alternator, power steering pump, etc.) can be used until you get all the mounting brackets for a 351W.
Old Oct 9, 2016 | 11:29 PM
Tedster9's Avatar
Tedster9
Be patient trying to free a stuck engine. Like the man said, it's been setting for years. Read up everything you can on freeing up stuck engines and all the problems that go with it, as for example stale gasoline turns to glue, even if it will burn. The web has a lot of great info, and a lot of it rightcheer in the archived posts. Internet search is your friend. Use it. Let us know what you find out and report back.
Old Oct 10, 2016 | 07:47 AM
Franklin2's Avatar
Franklin2
I have had engines sit at least 5 years and longer, and they do not get stuck. That's why I think there is a problem or a cause for it being stuck. Once it soaks for a few days take a breaker bar on the front crank bolt and try to turn it a little bit one way, and then the other way. If you get it moving a little bit stop and put some more stuff in it, I would use PB Blaster or Kroil. Something more aggressive than tranny fluid.
Old Oct 10, 2016 | 08:30 AM
Tedster9's Avatar
Tedster9
Air filter not installed over the years is never a good thing. Critters or vermin can move in through the carb and set up shop ... acorns, nests &c in the manifold or cylinders .. Also pull the valve covers and take look see esp. that everything is moving free and proper once you get it to turn over.
Old Oct 10, 2016 | 08:46 AM
Anderson80's Avatar
Anderson80
Air cleaner was on it but was taken off this spring. Carb works good still, i sprayed it down and got the Throttle and everything working, wont know if its shot till i have a moving engine.
Old Oct 10, 2016 | 09:19 AM
Tedster9's Avatar
Tedster9
OK... if the engine proves worth salvaging the carb can be rebuilt.
Old Oct 10, 2016 | 02:02 PM
maytag906's Avatar
maytag906
Northwest Indiana?
There's a yard in Warsaw Indiana, that has about 8-9 of those trucks. One had a decent dashpad. Lewis Salvage is the name. Warsaw is a straight shot east on US 30
Old Oct 10, 2016 | 07:38 PM
Anderson80's Avatar
Anderson80
Originally Posted by maytag906
Northwest Indiana?
That's awesome! Never heard of the place before
Old Oct 11, 2016 | 09:43 AM
  #28
Anderson80's Avatar
Anderson80
Well i found the key... It was tucked way up in the steering column under the shroud thats held on by one screw. Lifted the front up with the skidloader and straightened up the tires. Jumped the battery and starter still worked but it is definatly locked up. Gonna put some tires on it today to make it a roller and pull it up front where i can work on it... Time to put the seat back in
Buyerz
Sep 19, 2015 08:12 PM
Texas Chain Ring
Texas Chapter
35
Sep 28, 2012 02:54 PM
chriscris
Aug 24, 2011 06:55 AM
Hypoid
17
Mar 17, 2009 01:13 PM
masterbeavis
16
Dec 5, 2008 01:05 PM
