Which Dexcool to get?
Old Oct 9, 2016 | 06:48 AM
BCM's Avatar
BCM
On the road with the fifth wheel and the check engine light came on. The scan showed P2560 as the code. Google search alluded to 'low coolant level.' I am about an inch from the cold fill line. Of course, it is a Sunday so dealers are closed. An internet search shows that the majority say it is ok to use Dexcool 50/50 to top it off. Does the consensus still show that? There is a WalMart near my next stop and would like to top it off. I've never had it replaced (only 65K miles), so it is still the original coolant. Not sure about any leaks, assuming just five years of use caused it to go away. Will worry about that when I'm not parked on gravel later.
Can someone post a link to the WalMart Dexcool that is recommended? If Dexcool isn't recommended, please post a link to something that is so I get the right stuff. Truly appreciated. Thank you.
Old Oct 9, 2016 | 07:23 AM
senix's Avatar
senix
I loose a little on occasion. I think the hot temps and changing ambient temps has a little to do with it.
Exactly why I carry a gallon on board. I am running the motorcraft stuff as I could not find a consensus as to whether the off the shelf stuff is ok.
Get the spec # out of the owners manual and see if wally world or your local auto parts has it. (the spec stuff). Maybe a auto parts store would be best as they might be able to cross reference it.
Old Oct 9, 2016 | 09:07 AM
Just Strokin's Avatar
Just Strokin
As long as the bottle states it meets Ford's WSSM97B44 spec, you can use Dex-Cool or any of the other orange coolants. DO NOT USE GREEN NOR GOLD COOLANTS!
Remember, someone had to make the Motorcraft Coolant for Ford, might be Prestone, Peak or another MFG.
Old Oct 9, 2016 | 11:21 PM
mebe2k's Avatar
mebe2k
i've been running Rotella ELC (red) in mine for over a year.. no issues..if it lasts 300+K miles in the big trucks, it will last in my 6.7
Old Oct 14, 2016 | 06:59 AM
BCM's Avatar
BCM
Just a followup on this. Because I couldn't get a definitive answer I just continued down the road hoping the light wouldn't come back on... it didn't. Spoke to my service writer en route and he stated DexCool is an approved alternative so I could have used that. This is the definitive answer I was looking for and hope it helps others.
I did pick up the Motorcraft stuff yesterday and will keep a bottle on board.
Thanks for all the input.
Old Oct 14, 2016 | 07:30 AM
Just Strokin
I gave you the Ford Spec number that should have been on either of the Dex-Cool bottles, full or 50/50 strength. It should also be on the Peak or other ELC coolant bottles.
This spec number is in your owner's manual.
Old Oct 14, 2016 | 07:51 AM
BCM's Avatar
BCM
You did but I couldn't find it on the bottle and two AutoZone dudes with better eyes couldn't see it anywhere either so I walked away.
Old Oct 14, 2016 | 10:01 AM
Just Strokin
Prestone or Peak would have been as good as Dex-Cool
Old Oct 14, 2016 | 06:11 PM
FullMetalDiesel's Avatar
FullMetalDiesel
I think it would help If a picture is posted pictures of the Dexcool you are referencing? As this is the only Dex-cool product I see for Prestone. So there aren't worries with our engine or turbo seals with this one below??
<a href='https://postimg.org/image/mksfje7wt/' target='_blank'><img src='https://s14.postimg.org/wi3gcgfip/7020008_pst_af850_pri_larg.jpg' border='0' alt="7020008_pst_af850_pri_larg"/></a><br/><br/>
<a href='https://postimg.org/image/70l1suxsd/' target='_blank'><img src='https://s14.postimg.org/ipp1gtor5/a23f2277_6e1d_4d32_ad73_7576f8c05166_1_aa05d16e5.j pg' border='0' alt="a23f2277-6e1d-4d32-ad73-7576f8c05166_1.aa05d16e5"/></a><br/><br/>
Old Oct 14, 2016 | 09:16 PM
Dakster's Avatar
Dakster
I would have used a little distilled water to top it off until I could get the correct coolant. (and then adjust the mixture with 100% coolant when I got what I now is the right stuff)
Is yours below the cold line when the motor is at operating temp?
The previous couple of 6.7s I have had when cold the level is just below the line, at operating temps the coolant is about 1/2 way up the translucent part of the degas bottle...
Old Oct 14, 2016 | 09:29 PM
FullMetalDiesel
Thats good to know! How many miles since then?
Old Oct 15, 2016 | 07:00 AM
BCM's Avatar
BCM
Those are them. One is already diluted (the 50/50) and the other needs to be diluted with distilled water. What I was concerned about was the GM emblem on them.
big_brown_88_idi
Jul 22, 2018 12:00 PM
Future_LEO
Modular V10 (6.8l)
Apr 15, 2011 08:18 PM
aka rotten
1983 - 2012 Ranger & B-Series
Aug 17, 2010 11:32 AM
goatro
Apr 16, 2007 06:01 PM
frdrngrlvr
May 21, 2006 07:11 AM
