351w cam selection
Old Oct 8, 2016 | 09:59 AM
crash113's Avatar
crash113
351w cam selection
In the process of building a new motor for my 1997 F250HD and trying to decide on a cam. A lot of people recommend the crane 444232 which I noticed is a hydraulic flat tappet cam but I'm using a 96 roller motor as a base. Would it make sense to go backwards and install the crane or should I stick with the stock cam and run 1.7 roller rockers? Feel free to let me know any other suggestions.
Old Oct 8, 2016 | 01:05 PM
rla2005's Avatar
rla2005
Stick with the stock cam and run 1.7 roller rockers <-This
Old Oct 8, 2016 | 05:06 PM
Plowboy34's Avatar
Plowboy34
I'm building the same engine right now and I'm using the stock roller with 1.7 roller rockers. If you want low end torque for towing it is the way to go.
Old Oct 9, 2016 | 12:42 AM
crash113's Avatar
crash113
Perfect that's what I'm going for. What brand roller rockers are you running?
Old Oct 9, 2016 | 03:31 AM
GoinBoarding's Avatar
GoinBoarding
Crane Energizer seems to be the way to go. 5/16" pedestal mount. They seem to be backordered though. Ford Racing sells the same thing, for $80 more. Parts houses have those stocked but not the kit direct from Crane.
I too am doing a 5.8L build right now with stock roller cam and 1.7 RR. Lots of reading lead me to believe it's a great bang for your buck with no one being flat out unhappy. I added in a bottom end rebuild, fresh GT40P heads, long tube headers, and a Frankenstein intake. Goal is torque for me too. Getting excited to drive it!
Old Oct 9, 2016 | 05:13 AM
'89F2urd's Avatar
'89F2urd
Crane 444211 or comp xe258.
Old Oct 9, 2016 | 10:03 AM
crash113's Avatar
crash113
GoinBoarding what do you mean by Frankenstein intake? And '89f2urd I checked out both cams and they have an LSA of 112 degrees. I'm running the stock speed density and I was under the impression that I couldn't go below 114 degrees.
Old Oct 9, 2016 | 10:06 AM
'89F2urd's Avatar
'89F2urd
Both of those 112 lsa cams work with speed density, 114 lsa is a general rule of thumb, but not law...far more important than lsa is when the intake valve closes. Both of those cams intake closing events are early, generating lots of vacuum and lots of torque off idle.
They work fine.
Old Oct 9, 2016 | 11:13 AM
GoinBoarding
Porting a 5.8L truck lower intake to match a 5.0L truck upper intake. Discussed here: https://www.ford-trucks.com/forums/1...-manifold.html
It's a cheap way to gain some flow. How much? I don't know, but I didn't have the funds for an aftermarket intake.
6978sghfbjklgdfsjhkl
15
Jan 25, 2014 06:58 PM
Shwan_89HD
Oct 4, 2013 05:29 PM
fomoconate
May 19, 2009 09:44 PM
scott9320
Mar 25, 2003 10:25 PM
thenkel2
Mar 27, 2001 03:36 PM
