roller cam setup ?
Old Mar 21, 2003 | 08:28 PM
scott9320's Avatar
scott9320
Question roller cam setup ?
I'm getting ready to build a 393 for my truck. I want to use A roller cam in this one so I have a few questions for the pro's in here. I think I want to order the comp retro kit, here's where the first question comes in. If I use this kit can I get factory roller lifters to use with an E-303 cam. Now for the next question, can I get a set of pushrods for a later 351w that came factory with the roller cam.
here's what I have planned so far.
block bored .030 over
3.85 stroke crank
stock 351w rods
hyper 302 pistons
P and P E7TE heads with 1.94I and 1.6E
stealth dual plane intake (considering single plane)
750 holley double pumper
E-303 roller cam (I think,not sure on that yet,but definetly a roller)
headers with dual 3" exhaust
comp. ratio will be close to 10
I'm shootin for 400 HP and atleast that much torque.
thanks in advance,
scott
Old Mar 23, 2003 | 12:41 AM
Racerchuck's Avatar
Racerchuck
roller cam setup ?
First thing, If your 351w was not a roller block, you need the retro kit.
2. You will need a retro cam. They are ground on a small circle.
3. A Motorsports cam will not work. large circle grind.
4 Stock roller lifters will work and you need pushrods that are 7.70" long
The lifter bores are taller on a roller block. If you don't get a retro cam the lifters come out of the block too far, and oil leaks into the lifter valley.
A Comp Cams retro cam #35-442-8 is like an x-303
Old Mar 23, 2003 | 12:44 AM
Racerchuck's Avatar
Racerchuck
roller cam setup ?
E-303 is close to Comp Cams # 35-412-8
Old Mar 25, 2003 | 10:25 PM
goofin's Avatar
goofin
roller cam setup ?
if interested i have a comp cam # 35-410-8
260/533 roller cam, roller lifters, correct pushrods and the spyder and the xbars.about 10k miles on them. email me we can work out something.
Bootlegger's Deluxe
30
Jul 11, 2017 09:46 PM
87-XL-Squared
Mar 19, 2017 04:12 PM
Aaron-71
Oct 9, 2015 07:13 PM
boomer1ny
15
Dec 13, 2013 10:20 PM
F350 Strait
May 17, 2010 01:21 PM
