P0304, 4.2 engine, need help diagnosing
Old Oct 4, 2016 | 10:54 PM
Duncan Scott Millar's Avatar
Duncan Scott Millar
My E-250 4.2 has continuous miss on cylinder #4, p0304 changed coil pack, wires and plugs, No change. Cats were replaced a year ago fuel trim readings as low as -96.7%' as high as 53.3%. Would a cracked exhaust manifold cause this problem, after replacing coil pack, plugs and wires I noticed the crack between cylinders 5 and 6 on the engine side of the manifold about 1.5" long thickness of about sheet of paper. Here Is a picture of the fuel trim codes.
Old Oct 5, 2016 | 11:42 AM
Duncan Scott Millar
Anybody out there want to take a crack at this?
Old Mar 12, 2017 | 08:45 PM
Im50fast's Avatar
Im50fast
the EGR ports on my previous van V6 were all plugged up, except one cylinder; and that one cylinder had a misfire that was a bear to diagnose. PM me if you want more info.
Old Apr 3, 2017 | 07:11 AM
Im50fast's Avatar
Im50fast
I just stumbled across your post. I realize it's 9 months old.
Did you get it fixed?
Sounds similar to the issue I had with isolator bolts and EGR ports. PM me an update please
Nomadic Van
3.8 & 4.2L V6
Jul 19, 2016 10:02 PM
luckybarber
1997 - 2003 F150
Jul 29, 2014 01:53 PM
97f150girl
1997 - 2003 F150
Nov 22, 2007 12:04 PM
MikeFlorida
1997 - 2003 F150
Aug 10, 2007 09:23 PM
Qpats
3.8 & 4.2L V6
May 19, 2004 12:19 PM
