Gas gauge electrical help.
Old Oct 2, 2016 | 07:45 PM
df85732's Avatar
df85732
I recently purchased a new fuel tank and sending from MACS. I installed them last week and have driven the truck several times with no problems. Today I went to hook up the electrical and when I turned the key on, the gauge shot all the way past the full line. I only put around 5 gallons of gas in originally. Any ideas on what the problem might be? I did not use the original wiring harness because I plan to replace it but I did substitute a new wire and hooked it up just as the old one was. Yellow wire on my Truck. I plan to call MACs tomorrow but thought I would throw my dilemma out there for any ideas. I sure hope it's just a rookie mistake. Thanks
Edit - Just wanted to add that my electric system is 6 Volt Negative ground. They also did not include instructions so do I have the wires backwards? Live wire to the center screw and ground to the prong???
Old Oct 3, 2016 | 04:34 PM
SierraPapa's Avatar
SierraPapa
I would try it with the ground to the outside and gauge to the center. It all works off resistance to ground, which is why it's probably reading full. The resistance is equal as both are directly connected through the frame/metal of the vehicle.
Either that or the ground at the instrument cluster could be bad or not connected.
Old Oct 3, 2016 | 05:19 PM
ALBUQ F-1's Avatar
ALBUQ F-1
If the yellow wire goes to the back of the gauge, that goes to the center terminal, even if you are really 6v (-) ground. Are you really negative ground?
Old Oct 3, 2016 | 05:20 PM
jvmcc's Avatar
jvmcc
I think that I just installed the same sender. If so, it is supposed to work with original gauges. From what I understand, the original sender and gauges ran on 1.5 volts. This reduced voltage is sent to the sender from the gauge. Maybe you have something other than the original gauges?
deyomatic
Apr 25, 2015 07:09 PM
drumfield
Electrical Systems/Wiring
Aug 7, 2011 07:33 PM
mosgo1
Nov 19, 2008 08:02 PM
QCIGUY
1978 - 1996 Big Bronco
Jun 15, 2008 09:41 PM
Oregon Bob
Sep 14, 2006 11:52 PM
