8.8 rebuild HELP!
Old Oct 2, 2016 | 06:50 PM
quincyj34's Avatar
quincyj34
Exclamation 8.8 rebuild HELP!
I really need some help figuring this out. I can not for the life of me get the cross pin in with the axles are in but with the axles out the pin goes in.
This is the farthest it will go in:
<a href="http://s822.photobucket.com/user/quincyj34/media/20161002_181306.jpg.html" target="_blank"><img src="http://i822.photobucket.com/albums/zz147/quincyj34/20161002_181306.jpg" border="0" alt=" photo 20161002_181306.jpg"/></a>
This is the bottom side where it is getting caught on the right side but I dont know why:
<a href="http://s822.photobucket.com/user/quincyj34/media/20161002_181411.jpg.html" target="_blank"><img src="http://i822.photobucket.com/albums/zz147/quincyj34/20161002_181411.jpg" border="0" alt=" photo 20161002_181411.jpg"/></a>
can some please help me figure this out.
Old Oct 2, 2016 | 08:17 PM
Lead Head's Avatar
Lead Head
Are you pulling the axles back out tight against the C-Clip?
Old Oct 2, 2016 | 08:34 PM
Shadow944795's Avatar
Shadow944795
This maybe. I would see if you can put a slight chamfer on the end its stuck on pin wise. I'ma try the same with my practice axle I screwed up two months ago XD
Old Oct 2, 2016 | 09:22 PM
quincyj34's Avatar
quincyj34
I sure am. Ive tried turning the c-clips, switch them around, switch the axles
Old Oct 2, 2016 | 09:24 PM
quincyj34's Avatar
quincyj34
I did use the carbon fiber clutch pack which i bet is a tad thicker.
Old Oct 2, 2016 | 10:37 PM
Lead Head's Avatar
Lead Head
You're sure the clutch pack clearances, etc.. and all that are correct? If so, have you just tried using a flat-head screwdriver to pull the pin into position?
quincyj34
Sep 25, 2016 09:49 PM
Cowboy34
Jun 19, 2010 01:50 AM
20024.2V-6
1997 - 2003 F150
Oct 22, 2007 06:08 PM
Paulstinkerinnow
Feb 21, 2004 08:33 PM
