Howling noise
Old Oct 2, 2016 | 09:27 AM
CPB1's Avatar
CPB1
Howling noise
2005 F250 195k miles. The truck has developed a howling noise comeing from what sounds like the driveline. It is most apperant at slow speeds with the windows up. It almost sounds like tire growling on the pavment but I can also hear it driving through the grass.
The last vehichle that i heard this from was my dd and ended up being a pinion bearing.
I put it on jack stands, removed the tires axles and driveshaft, spun the pinion yoke by hand it feels smooth. I also checked the rear hub bearings and they feel fine also. With the axles out and it up on jack stands i ran the truck and could still hear the noise. It almost sounds like it is comeing out of the T case output. The T case is a NP 271(manual shift).
Any ideas??
Thanks guys.
Old Oct 2, 2016 | 11:25 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
When I hear the word HOWLING, the only thing I think of is the rear end! Check the fluid level in there. Got 4W drive? MAYBE front differential.
Old Oct 3, 2016 | 03:50 PM
CPB1's Avatar
CPB1
Thanks Bud that's exactly what it sounds like a howling rear.
The fluid level is good and it spins real free, no binding feeling in the bearings.
The mystery continues.
Old Oct 3, 2016 | 07:18 PM
Mich6.0's Avatar
Mich6.0
Are your hubs locked ,I had a vibration and it was the bearing in the front driveshaft knuckle (c-v ball) I think its called.
Old Oct 3, 2016 | 11:29 PM
Yahiko's Avatar
Yahiko
The center support bearing???
Sean <BR>
6.0L Tech Folder
Old Oct 4, 2016 | 09:15 AM
Kemicalburns's Avatar
Kemicalburns
i had this very sound myself, people kept telling me it was the tires. Well low and behold i got the front end jacked up and spun the front passenger wheel and there it was. Truck has 117k miles on it.
what i noticed was it would kinda stop when i turned left on city streets at low speed. if i turned right it would come back slightly. for your sake i hope its not the rear end.
Old Oct 4, 2016 | 05:23 PM
CPB1's Avatar
CPB1
So it was the hub/bearing?? Or the tire??
Oddly thats the only one i didn't check, pass side front.
Ill be checking that this week.
Thanks everyone for your input.
Old Oct 4, 2016 | 05:26 PM
CPB1's Avatar
CPB1
Sean <BR>
6.0L Tech Folder
Thanks. Sean, that bearing has been changed out twice now in the last 4 yrs. Doesn't meen its not the culprit thouh.
Old Oct 4, 2016 | 05:29 PM
Yahiko's Avatar
Yahiko
You got it good and lined up with the shaft? I found that the one that I
had fail was not at 90º to the shaft centerline.
However the hub bearing could be a better place to start.
Sean <BR>
6.0L Tech Folder
Old Oct 5, 2016 | 11:53 AM
Kemicalburns
the dealer replaced the bearings and front ujoint/axle shaft as well.
Old Oct 5, 2016 | 04:03 PM
CPB1's Avatar
CPB1
OK thanks. Thats the next thing one the list.
Old Oct 8, 2016 | 09:03 AM
CPB1's Avatar
CPB1
Think I found it
I took the front pass side wheel off and could not realy feel anything spinning the brake rotor so I put the wheel back on and gave it a good hard spin and there it was. It feels like it is the hub/bearing. Next question is what brand should I go with.
Old Oct 8, 2016 | 10:11 AM
CPB1's Avatar
CPB1
Made 2 short videos.
Old Oct 8, 2016 | 11:27 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Ford product lasted 195,000 miles +. Any reason to go with anything else?
Old Oct 8, 2016 | 02:27 PM
CPB1's Avatar
CPB1
I can't argue with that.
Gotta research and see how much its going to set me back.
