Howling noise
Old Oct 8, 2016 | 02:32 PM
CPB1's Avatar
CPB1
[QUOTE=BPofMD;16630833]Ford product lasted 195,000 miles +. Any reason to go with anything else?[/QUOTanytI can't argue with that.
Gotta do some reasearch and find out how much it's gonna set me back.
Old Oct 8, 2016 | 03:59 PM
KDAVID1's Avatar
KDAVID1
[QUOTE=CPB1;16631120]
All good bit Going to be getting at least 1 myself.
Old Oct 8, 2016 | 06:22 PM
Per4mance's Avatar
Per4mance
I was coming back from washing parts at my buddies shop and I got a hint of a wheel bearing noise. I'll give you one guess who's bearings I replace them with not too long ago
Old Oct 8, 2016 | 08:04 PM
CPB1's Avatar
CPB1
So you replaced one on your F250 and now its makeing noise? I give up what brand did you use?
Old Oct 8, 2016 | 08:07 PM
CPB1's Avatar
CPB1
[QUOTE=KDAVID1;16631234]
Did you start your research? Amazon has the Ford OEM $435 for 1. You find it elsewhere?
Old Oct 8, 2016 | 08:20 PM
Yahiko's Avatar
Yahiko
Moog?
Sean <BR>
6.0L Tech Folder
Old Oct 8, 2016 | 08:23 PM
Per4mance's Avatar
Per4mance
Ding,ding ding............we have a winner.........I hate doing rework! And it was on my Excursion,I just did the whole front end less than 2000 miles ago
Old Oct 8, 2016 | 08:27 PM
KDAVID1's Avatar
KDAVID1
I've been keeping an out out for almost a year since i was expecting this when i did my front end work almost a year ago. So far that's about the best price I've seen....I consider that a good bit although in the grand scheme of things it isn't I suppose.
Old Oct 8, 2016 | 08:31 PM
CPB1's Avatar
CPB1
That would be a different bearing the your F250 but I get the idea. Especially after reading what Jack had to say about replacement auto parts.
Old Oct 9, 2016 | 10:49 AM
CPB1's Avatar
CPB1
Originally Posted by Yahiko
Moog?
Sean <BR>
6.0L Tech Folder
Sean, isn't there a service kit for the front hub bearing?? I thought i saw you posted once.
Old Oct 9, 2016 | 11:00 AM
CPB1's Avatar
CPB1
I may be mistaken, the correct part number is AC3Z-1104-D which is closer to $500.
Old Oct 9, 2016 | 11:43 AM
04badford's Avatar
04badford
I installed Timkin barrings, I think moog was the barring I installed about a year ago that dam near flipped my truck out in the Arizona desert, they heated up so bad I couldn't get the spindle nut to brake , had to replace the whole knuckle assembly made a big mess of things.
Old Oct 9, 2016 | 11:51 AM
  #28
Per4mance's Avatar
Per4mance
Moog is really starting to bite the big burrito. I'm not using their stuff anymore. I'm a fan of XRF now. Price is right and you can't beat the warranty.
Old Oct 9, 2016 | 05:21 PM
  #29
Yahiko's Avatar
Yahiko
The only "KIT" I know about if the one that gives you all the parts
from and including the ESOF vacuum seal out to the hub lock. No bearings in it.
Is that what you talking about? If that is it I don't have a part number
for it. I did get that from Ed.
Sean <BR>
6.0L Tech Folder
Old Oct 9, 2016 | 06:11 PM
  #30
CPB1's Avatar
CPB1
Sean <BR>
6.0L Tech Folder
5C3Z-2B513-AA
Let me know what you think. Thanks
