Sponsored by: Auxito
Lost odometer display on 2001 F150 4X4
Old Oct 1, 2016 | 12:26 PM
66with352's Avatar
66with352
I parked my truck yesterday and know the odometer display was working. Started truck up this morning and no display. My brake light (idiot light in dash) was slightly illuminated as well. The truck ran fine and when I shut it off and started it back up again, the odometer was still out but the brake light was off. Any thoughts? I saw a you tube video showing a cold solder joint on the back of the dash motherboard. I hate to pull that all apart if there could be something else that is simple. Thanks for any suggestions.
Old Oct 1, 2016 | 08:04 PM
Bluegrass 7's Avatar
Bluegrass 7
Well that's where the issue is no matter how you feel about it.
Things heat cycle over time and can go into fault as a result.
Good luck.
Old Oct 3, 2016 | 07:12 PM
66with352's Avatar
66with352
So the temporary fix was to jump in truck yesterday and start it up. Looked at the odometer and it was illuminated again. Got a gremlin running around in there but for now, its on. Any bets on tomorrow? its a 50/50 chance.
Old Oct 3, 2016 | 07:28 PM
ExplorerTominCO's Avatar
ExplorerTominCO
The cold solder joint is a common issue and really easy to fix. My odometer would come and go for over a year before I finally tore into it to fix it.
Don't know about the brake light.
Old Oct 3, 2016 | 07:56 PM
66with352's Avatar
66with352
The brake light turned out to be a sagging e-brake pedal. I never use it and it has been loose since I got the truck (been addressing more critical stuff). It was just sagging a little bit. I lifted it with my toe and light went out. Doh . I'll get to that one of these days
Old Oct 13, 2016 | 09:26 PM
bass-n-fire's Avatar
bass-n-fire
I had the same issue with the odometer. Tried the cold solder fix and worked like a charm. Not as bad as it sounds. Removed, fixed, and reinstalled in less than an hour.
Old Oct 14, 2016 | 06:42 AM
66with352's Avatar
66with352
Bass, Thanks for the info. Glad to hear its not as bad as it initially appears to pull it apart. At this point, the odometer display came back on and has remained working for about a week now. I guess I hit a bump at the right angle. lol I'll ride this wave until it fails again and then probably pull it apart.
Old Oct 14, 2016 | 07:38 AM
ExplorerTominCO
Like I said earlier, I went for a year with mine working part of the time. Usually a good hard tap on the odometer cover got it working again.
OHSD
Jan 6, 2018 09:38 PM
josiewales
Jan 19, 2017 12:20 PM
Grinder Man
2004 - 2008 F150
Oct 20, 2013 05:59 AM
Miescha
Dec 10, 2005 05:01 PM
SShank42
Bronco II
Feb 9, 2005 08:20 PM
