Illinois Chapter Join Chapter Leader: wpnaes
Illinois Chapter October BS Thread 2016
Old Oct 18, 2016 | 08:04 PM
  #1606
Zip's Avatar
Zip
That's me talking. All he seems to say is banana.
Old Oct 18, 2016 | 08:05 PM
  #1607
56panelford's Avatar
56panelford
So how are your days off going..? I've started wet sanding on the cab now..
Old Oct 18, 2016 | 08:07 PM
  #1608
Zip's Avatar
Zip
That sounds long and tedious.
I picked up a coolant filter and some transmission fluid this afternoon. Have something to do tomorrow.
Old Oct 18, 2016 | 08:12 PM
  #1609
56panelford
I have something to do for most of the winter...lol I have to switch over to finer paper tomorrow, started with 1000 grit to speed the process will end up using 3000 grit before polishing..
Old Oct 18, 2016 | 08:13 PM
  #1610
Zip's Avatar
Zip
The end result is worth the effort is it not. I guess with the 3000 it doesn't look like much is happening though.
Old Oct 18, 2016 | 08:15 PM
  #1611
56panelford
It will take out all the really fine scratches before polishing. I but a small pneumatic polisher for the task...
Old Oct 18, 2016 | 08:16 PM
  #1612
Zip's Avatar
Zip
You use a cut polish or something similar for the final work.
Old Oct 18, 2016 | 08:24 PM
  #1613
56panelford
I have a Makita polisher and use a cut polish, can't think of the name of the top of my head right now, but you just keep adding water with it as you polish and it keeps getting finer as you polish . You end up with a mirror finish..
Old Oct 18, 2016 | 08:26 PM
  #1614
Zip's Avatar
Zip
All this talk makes me think I should get to one of mine in the spring.
Old Oct 18, 2016 | 08:27 PM
  #1615
Zip's Avatar
Zip
What kind of paint do you use?
  #1616
tiny1's Avatar
tiny1
Moderator & CL
Hey Zip.....
  #1617
donjamer's Avatar
donjamer
Good evening Rick, John, Neil, Chris and everyone
Hope you had a great tuesday
Old Oct 18, 2016 | 08:28 PM
  #1618
56panelford
Which one do you have in mind... I hope to have this one ready for spring, time will tell though..
Old Oct 18, 2016 | 08:30 PM
  #1619
56panelford
I started out with bare metal and used an epoxy primer made by Endura, then used PPG Omni high build primer and same brand base coat and clear..
Old Oct 18, 2016 | 08:31 PM
  #1620
56panelford
Howdy Neil and Don...good of you to join us..
