Sponsored by: Real Truck
Need help diagnosing noise
Old Sep 29, 2016 | 07:01 AM
xtamer's Avatar
xtamer
02 f250 SD 5.4 zf6 manual xcase ext cab long bed
When I'm cruising down the highway it's most noticeable. 5th gear anywhere from 65mph+ I'll let off the gas and it'll make a "errrRRRt" until I press the gas again.
I've recently installed new-
Front u joints, ball joints, hub assemblies, rotors, calipers, pads
Rear drive shaft u joints
Front diff fluid
Trans fluid
Tcase fluid
4" zone lift kit
All of these things did nothing to effect the noise. it seems to be coming from between the clutch and rear shaft (either clutch, trans, tcase).
I don't think it is a motor noise or suspension noise. Any input is appreciated
Old Sep 29, 2016 | 08:56 AM
Boaterguy's Avatar
Boaterguy
How many miles on the truck? I don't know if this helps but, back in the day when I had a 1995 F250, I developed the same noise around 150k. At speed, every time I would let off the gas I would hear a loud howl or groan from under the truck. Get on the pedal, it goes away. It turned out to be an issue with the rear differential. Had a Trans shop rebuild and it went away. Might want to run it by a transmission shop and let them hear it.
Old Sep 29, 2016 | 10:13 AM
xtamer's Avatar
xtamer
It's at 150k too. Has 4.10 gears. And the rear diff is the next on my list to service too
Old Sep 29, 2016 | 10:44 AM
Boaterguy's Avatar
Boaterguy
Yes, my '95 had the 4.10 gears and limited slip. If yours has a drain plug, it would be better to remove the cover and look inside. My gears were worn out causing the noise. Just a thought here since I have never lifted a truck other than a levening kit, but I have heard from some of my friends who like to jack their trucks 6' in the air that they have to have the driveshaft lengthened to prevent stress and wear on the u joints. Not sure if that would apply in your case but could also be a source of noise........Good luck.
Old Sep 29, 2016 | 11:06 AM
xtamer's Avatar
xtamer
The place I got the kit from is pretty reputable and said I wouldn't need a carrier bearing drop or anything, not saying I don't but I don't think I do. I'm gunna check rear diff and see what it's like in there.
Old Sep 29, 2016 | 11:21 AM
Boaterguy's Avatar
Boaterguy
Post back when you can. I would like to know what you found in there.
Old Sep 29, 2016 | 01:31 PM
don123's Avatar
don123
It could be the pinion bearings. My old f150 would make a loud growling noise only when I would let off the gas and stop as soon as I gave it gas. I tore the rearend apart and the pinion bearings were shot. While I had it apart I replaced the carrier bearings,wheel bearings,and clutch packs for the LS.
Old Oct 5, 2016 | 09:03 PM
xtamer's Avatar
xtamer
Change the rear diff fluid. I cleaned it out really good and everything looked ok. It's still making the noise. Took a couple videos of the noise below
https://youtu.be/GuVBbsLmzWw
https://youtu.be/k6RiM19DrXQ
bshort09
Apr 29, 2015 07:18 PM
scraprat
Jun 20, 2011 05:37 PM
jw miller
Jul 2, 2007 10:33 AM
jater76
Apr 17, 2007 10:50 AM
hydrology_joe
1983 - 2012 Ranger & B-Series
Mar 10, 2005 08:23 AM
