noisey posi?
Old Jun 28, 2007 | 09:24 PM
jw miller's Avatar
jw miller
noisey posi?
My 84 F150 3.55 posi the one with bolts on rear with stamperd steel inspection cover,seems to make a steady noise when under power(not coasting) Thinking maybe it might help to remove inspection cover clean it out as best possible then new lubricate.What would be a good lubricate to use in this? JW Miller
Old Jun 28, 2007 | 10:36 PM
zpmps2's Avatar
zpmps2
have you changed your u joint in a while, mine did that then started vibrating then i got pissed at it one night w/ a girl in the truck "wouldnt let me go over 35, the truck was shaking so bad, so i dumped the clutch at a stoplight, and i heard clunking, so i walked a block to Autozone and got a new one and rented a 1/2 inch wrench and put it on and i was on my way. Remember, always repair before dating hot girls, especially in a redneck truck.
Old Jun 29, 2007 | 06:47 AM
Sycostang67's Avatar
Sycostang67
What kind of noise? I have had u-joints that made a steady noise while accelerating too. I cant imagine a posi would make noise going straight, around a turn maybe.
Old Jun 29, 2007 | 11:49 AM
jw miller's Avatar
jw miller
noise in drive line!
Posi lube needs to be changed out any ways today it is org. I am of that as was trans fluid. It could be center bearing on drive shaft to I suppose.Really need to drive it more often. Or put on jack stands and run in gear to hear where noise comming from. If I find problem will inform all. JW Miller
Old Jul 2, 2007 | 10:33 AM
jw miller's Avatar
jw miller
noisey posi! For got to check back on this.
I found front seal starting to leak a little but fluild still full.Will wait to refill after I get a chance to change seal.Had a chance to but some miles on the truck and I do not notice any strange noise!Me thinks my age(70) is really catching up to me. JW Miller
jw miller
Jul 6, 2009 10:37 AM
jw miller
Dec 31, 2007 12:22 AM
jw miller
Jul 30, 2007 01:06 PM
jw miller
Jul 22, 2007 12:12 PM
jw miller
Jul 15, 2007 04:53 PM
