Rear Block sizes
Old Oct 3, 2016 | 09:59 PM
  #31
RainDesert's Avatar
RainDesert
Originally Posted by KubotaOrange76
Sounds reminiscent of when the 99 superduties came out. All the 4x4 came with 4" rear block, after awhile ford started changing peoples out to a 2" because they were too high. I wonder if history will repeat itself?
I remember that like yesterday. My rancher friend brought home a new '99 F250 Reg Cab V10 and had to have the blocks replaced to fit under the gooseneck. This is exactly how I feel about my new 250.
Old Oct 3, 2016 | 11:33 PM
  #32
Kenv's Avatar
Kenv
Kubota......Ford did not start changing out the 4" to 2" for customers. In mid-year 2000 all the new F250s off the line came with the 2" blocks instead of the 3 1/2. It was a factory change...the dealers were maybe doing it IF you asked them to. It remained like that for many years. All F350s remained on the 3 1/2.
Old Oct 4, 2016 | 04:15 AM
  #33
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
Ford had problems early on with 5th wheel owners complaining about the bed height and trailer clearance. Ford swapped in the shorter blocks for free.
I remeber countless threads about it on ford-diesel. Com
I agree it changed around that time, and continued until 15-16 when they started slipping the 4" back in some of the 250's
Old Oct 4, 2016 | 08:17 AM
  #34
Mayberry's Avatar
Mayberry
Originally Posted by dh1200
Another thing to consider is if you get it dead level according to the tape measure, it may "look" lower in the rear, from the way the body is shaped on these new trucks. I say this because, from the above pics, this guy says his truck is level with the camper hooked up. By looking at the wheel well gaps in the front and rear, they do look the same, so it would probably be level if you put a tape to it, but to the eye, it looks lower in the rear. So if you want it to look level, you may want to keep the rear slightly higher than the front. I dont know this for sure, im just going off of what ive been seeing in pics.
I am just looking for an inch or so. 1.25" might be perfect. I want a little rake to the front, but still want a little larger tire.
Zoodad... hoping you find a 2wd today!
Old Oct 4, 2016 | 08:39 AM
  #35
System's Avatar
System
Prolocutor
They also had a TSB to change 2" to 4" on 250's for a while to compensate for sag while loaded or towing.
Old Oct 4, 2016 | 10:06 PM
  #36
ZooDad's Avatar
ZooDad
Retired guy fixn stuff
So went by the dealership today. The XL I saw turned out to be a 4x4. So rear blocks are the same.
Sorry. I will keep an eye out.
Old Oct 4, 2016 | 10:16 PM
  #37
dh1200's Avatar
dh1200
sounds good, thanks for trying though.
Old Oct 5, 2016 | 09:34 AM
  #38
Mayberry's Avatar
Mayberry
If you were to see one, and the blocks are shorter,... Please take a picture of the vin plate. It will help in ordering the correct parts.
Eggs2bacon
Feb 8, 2017 02:09 PM
MDSuperDuty
Mar 16, 2012 03:40 AM
mgman
General Automotive Discussion
42
Feb 21, 2005 10:33 AM
t_dickie
Dec 14, 2004 02:27 PM
2stumpPullers
May 13, 2002 05:35 PM
