Safety Chain Hooks
Old Sep 24, 2016 | 08:23 PM
rawn77's Avatar
rawn77
Follow up:
I wasn't able to use my safety chains after all.
Tried Lowes, found a bigger hook, still too small.
Drove 700 miles while towing my Airstream with no safety chains.
This is ridiculous and dangerous!
Surely someone has hooks that will fit.
Anyone?
Ron
Old Sep 24, 2016 | 08:43 PM
99SuperDuty2017's Avatar
99SuperDuty2017
Because of your post I am looking on Amazon!!!
Old Sep 24, 2016 | 09:45 PM
gbkeith's Avatar
gbkeith
Can you pass the chain through both holes and hook it back to itself? Or put a shackle through both holes and then hook the chain to that? I'd bet money that Crosby or CM manufacture something that will do what you need. Industrial Rigging Hardware for Lifting & Material Handling from Westech Rigging Supply
Old Sep 24, 2016 | 09:54 PM
Rasalas's Avatar
Rasalas
Originally Posted by rawn77
Follow up:
Anyone?
Ron
Try a commercial construction supply, heavy duty truck supply or even Tractor Supply.
Old Sep 24, 2016 | 10:00 PM
gbkeith's Avatar
gbkeith
Loop a short chain, maybe 6 or eight inches, through both holes and then attach both ends of that chain together with a double clevis link. Do it on each side of the hitch. Hook your chains to the loops. Ace, Lowes, Home Depot, or Tractor Supply should all have shackles, chains, and fittings and be open on a Sunday morning.
Old Dec 30, 2016 | 09:38 PM
caadoptees's Avatar
caadoptees
Follow up:
Anyone?
Ron
A fellow Airstreamer here.
I found these some quick links (5/8") that fit.
Some are questioning the strength of these, but...
Here is the thread: https://www.ford-trucks.com/forums/1...l#post16829847
Old Jan 20, 2017 | 07:01 PM
K A M's Avatar
K A M
So I tried to hook my safety chains to the truck and they don't fit. So I was thinking I was going to have to change them out on my three trailers. On my way to go search what will work I got to thinking that if I change mine out then what will happen when I pull someone else trailer. It probably won't fit either. So for me changeing out the hooks is not an option. I need to find a shackle that will work and listen to them rattle back there.
Old Jan 20, 2017 | 07:33 PM
AK_SuperDuty's Avatar
AK_SuperDuty
https://www.ford-trucks.com/forums/1...in-hookup.html
See page 9 for my solution. I installed hammerlok unions. They are super clean and far stronger than a shackle. And they don't rattle at all.
Old Jan 20, 2017 | 07:37 PM
archer3's Avatar
archer3
If you're running a 17' I doubt you'll hear any rattle unless you drive with your windows open. They are pretty quiet inside compared to the older model SD.
coolemoff1
Feb 22, 2018 05:09 PM
MissIndependent
19
Mar 3, 2009 10:27 PM
MissIndependent
All Things Towing
Mar 3, 2009 08:59 PM
Yukon
All Things Towing
Jul 27, 2006 09:27 AM
Wheels
All Things Towing
15
Jan 23, 2003 05:39 PM
