More on safety chains
Old Mar 1, 2009 | 08:46 PM
MissIndependent's Avatar
MissIndependent
did a quick search of the forum and didn't turn up an obvious answer to my questions:
how do you determine the correct length for safety chains?
what is the safest/recommended way to attach them to the trailer?
i tow a 2-horse straight load tagalong with a max weight of 8100 lbs with the truck in my sig
it already has chains on it, but i have no idea how good they are or even what they're rated, so i think i'm just going to put new ones on
Old Mar 1, 2009 | 09:37 PM
c.f.moore's Avatar
c.f.moore
The correct length would be the length needed to go from trailer frame attachment point to tow vehicle attachment point, while the chain "sags" in the center to within 5"-6" of the ground. Also, the chains should cross each other when installed (so in theory when the trailer comes loose, the trailer tongue will be cradled by the chains and prevent the trailer tongue from violently digging into the pavement and causing more problems).
I believe that 5/16" chain would be more than sufficient for your purpose. Attachment to the trailer can be by bolt and washer or welding.
Another possibility would be to have a couple of short steel cables made (same length as the chains would be)with "eyes" swedged at each end. Cables are a lot easier to deal with and don't collect as much dirt, rust, etc.
Good luck
Old Mar 2, 2009 | 07:14 AM
grafekie's Avatar
grafekie
Cables can't handle the weight. I got transport chain, the strongest I could find, and 1/2" grade 8 bolts to attach to the tongue.
As far as length, they need to be long enough to loop gently and not get too tight when in a sharp turn. They absolutely should not be overly long, so proper adjustment is key. One trick I inadvertantly learned when chaining a car hauler is if you buy the proper hooks (and not just "S" hooks, which are FAR too weak for any size trailer) they can be adjusted up and down the links with just the quick exchange of the cotter pin. That way you can customize the length based on each truck. In my case, my roomate's chevy's clips required a shorter chain than my neighbor's (it was her trailer) Dodge, which needed longer chains. I've never ever had a problem with different lengths before this paticular trailer.
Old Mar 2, 2009 | 09:37 PM
MissIndependent
hmmm, so S hooks are a no-no...i guess my gut reactions are usually on the right track, because i was thinking of getting something more secure when i put the new chains on
thanks
Old Mar 2, 2009 | 10:48 PM
believer45's Avatar
believer45
I have used something like THIS for years with great success.
Semi trucks use hooks like THIS. As you can see, they are rated from 7,800 lb trailer to 65,000 lb trailer.
Old Mar 3, 2009 | 05:18 AM
shorebird's Avatar
shorebird
This is definitely the way to go;
Old Mar 3, 2009 | 06:32 AM
petey shoes's Avatar
petey shoes
shorebird, that's the ticket! just make sure they are "quality" hooks--not cheap crap
Old Mar 3, 2009 | 05:08 PM
grafekie's Avatar
grafekie
Yup, those are the clips I used. They aren't cheap ($10ish each) but they can be readjusted, removed, reinstalled, and are very strong. The clip works great to keep the hook latched on. Just use those, some 3/8" or whatever you can fit on the trailer grade 70 transport chain, and some grade 8 bolts to finish it off. I think the chains I installed on my friend's trailer cost me $25, including a cobolt tipped drill bit to widen the slits the chains attached to.
I wouldn't recommend the other link, they are a pain in the butt to latch when they rust, and they are very very weak if the screw isn't tightened every time you hook the trailer.
Old Mar 3, 2009 | 08:22 PM
MissIndependent
thanks for the all info...might have to go see what i can order through napa, they're advertising a sale this month on all towing supplies. how kind of them lol
truck needs a brake controller as well...
Old Mar 3, 2009 | 08:59 PM
believer45's Avatar
believer45
I took a look at the ratings for THESE and have changed my mind. 5/8" is only rated at 6800 lbs, 5/8 grade 80 transport chain is rated at 18,100 lbs - I learned something today. I am removing them before I tow again, probably once I get the truck back on the road.
