2013 hazard light wiring
Old Sep 19, 2016 | 07:59 PM
Ferdferever's Avatar
Ferdferever
Hi Guys! have a 2013 6.7l super duty Lariat. I want to install flashing LED lights to work in conjunction with the hazard lights. The leds have their own controller and will be separate from any other lights/wiring. What I need is some way to trigger a relay to turn on the led's. Was hoping to tap into the hot lead off the hazard switch itself but that's not an option! Any ideas? Thanks in advance for the help!
Old Sep 20, 2016 | 05:10 AM
Just Strokin's Avatar
Just Strokin
There appears to be a Brown wire with yellow stripe that triggers the hazard lights and goes to the Body Control Module (BCM) pin 32 of connector C2280B. Check this wire to see if it will meet your needs. If should have 12v when on and 0 volts when off.
I do not have a 2013 wiring diagram but the location to pick it up would probably be over by the BCM.
Old Sep 26, 2016 | 06:52 PM
Ferdferever
Hey Larry! Thanks for the hand! Unfortunately.... that wire is hot all the time. Tried my volt meter on the brown/stripped yellow wire right off connector c2280b. No go. Any other ideas? Thanks!
Mason_72_F100
Jun 18, 2019 08:03 AM
Royson12
22
Jun 24, 2015 04:17 AM
Sebasterd
Mar 29, 2015 09:41 AM
FordIowan
Dec 25, 2013 03:45 AM
nitro94
Electrical Systems/Wiring
Apr 17, 2000 06:05 PM
