Keyless entry honking twice on lock, remote start won't work.
Hello all!
I have a 2011 F250, with the Lariat Ultimate package that includes factory remote start.
Las week, I Got out of the truck, pressed the lock button twice (like I always do), but this time the horn honked loudly twice and the lights did not flash.. like a door was ajar. The interior lights are turning off and all doors are locking properly.
Remote start doesn't work.. I get one honk when I try that.
Opened and fully closed all 4 does and the hood.. still honked twice and no lights flash.
Start the truck.. no warning notification any doors are open.
Information center (under system check) also shows "Doors OK".
I tested all the door sensors by opening and closing each door individually with the truck running and I am getting the proper notifications the doors are open, and the notifications go away when the door is closed.. so everything seems to be working as designed.
I've also replaced the hood-pin switch thinking that may have gone bad but I'm still getting the same problem.
Not sure what's wrong with my truck.. any ideas?
(Truck is 100% stock)
I replaced the hood switch sensor, still getting the same problem.
Checked both switches with a voltmeter, it appears both switches are working properly and showing the hood as closes.
No, but both remotes are doing the same thing.
I can't even get the parking lights to blink by locking the doors via the door keypad like it usually does... Seems like the problem is in the truck and not the key fobs.
Figured it out guys. When I went to check the fuses (as mentioned by someone else the 6.7 Facebook group), I found that a dealer had added on their own security system (I guess it's just a shock sensor really).. one of the connectors came undone that plugged into it. I plugged it in and everything is working as designed. Thanks everyone for your help!
