1998 Eddie Bauer 4x4
I had water leak down into the driver's side dash area and down along the door. Now, my driver's side power window does not work. It is making the clicking noise, but the window stays put. The clicking noise is not the switch, but it is coming from in the door. Any ideas? How would I fix this?
The klicking noise you hear is the window relay, which is normal. More than likely you fried the motor, pull the door panel and check it out.
